    Some buttons in "Modern Look" are too small
    BigMikeB
    some buttons in Modern Look are too small for German translations. Can you size them dynamically, based on the length of the translation?
    In some cases the image is also drawn left of the button border and the same for the text on the right:
    By the way, it gets worse in touch mode.
    Translations
    Some Strings in PowerArchiver 2019 are not translatable
    BigMikeB
    Hi, most of the strings in the SmartAI settings dialog are not translatable at the moment:
    I thought I’d get updated language resources before the release.
    Will you provide updated language resources in the near future?
    Translations
    %APPNAME% should not contain the version
    BigMikeB
    In the translation files, there’s the variable %APPNAME% which is replaced by “PowerArchiver 2018”.
    But the language texts suggest, that it should only be “PowerArchiver”. That’s not really a translation issue, since even the English text is wrong.
    See the example:
    There’s no “PowerArchiver 2018 9.xx”, the hint should tell me, that I need PowerArchiver 9.xx or later.
    I found more occurences where “2018” doesn’t fit, mostly in hints. On some occurences (e.g. the window titles) it makes sense, but isn’t really needed.
    Translations
    let's introduce ourselves !
    M
    hi all !
    We’ve been working on translations for years, without really being able to put a face on each one of us! Here’s mine!
    See you soon!
    Translations
    German Translation
    Z
    I have found a bad typo in PA 2009 Beta 1:
    Forschaufenster -> Vorschaufenster
    And some word (order) suggestions:
    Neu Archiv -> Neues Archiv
    Öffnen Archiv -> Öffne Archiv or Archiv öffnen
    Verschlüsseln Datei -> Datei verschlüsseln
    Konvertieren Archiv -> Archiv konvertieren
    Interface -> Oberfäche (if you translate all words into german, why not interface?)
    Clear History -> Verlauf löschen
    And please, clearify “Windows benutzen” -> i know, i use Windows ^^
    Translations
    PA2017 translation issues
    J
    alt text
    As you can see, the “This product is licensed to:” has not been translated to Portuguese
    Also the 2nd button has some truncated words, as well the bottom, the C from Correio eletrónico
    Translations
    Danish Translation
    M
    This is a feedback thread for the Danish translation.
    Please write in Danish. :)
    Her kan man skrive feedback til den danske oversættelse.
    Så hvis der er ord, sætninger eller andet, i mener der bør rettes i den danske oversættelse, så er i mere end velkommen til at foreslå dem i denne tråd.
    /Mads
    Translations
    PowerArchiver 2015 Toolbox License Transfer
    Hi, i got a few PA 2015 Toolbox Licenses on hand, so i thought of giving away one of my PA 2015 Toolbox License away, to a good friend of mine, and i will not be using it anymore.;)
    Could you all please can do it for us, on our behalf.:confused:
    Thank you very much!:D
    Best regards.:)
    Translations
    Saying Hello
    M
    Hello to all folks,
    I am newbie here, just joined this forum site
    Translations
    Polish translation
    K
    Hi there,
    PowerArchiver is great, but I’m really sorry, that there isn’t polish language in the newest version.Is anybody working over polish interface? If not I can do that. Just tell me how.
    Translations
    Errors in Brazilian Portuguese translation
    The Brazilian Portuguese (pt_BR) translation has lots of typos like missing, duplicated or transposed letters…
    Translations
    Spanish translation
    nobody in the office knows Spanish well enough, you need to compile issues and we will send it to our Spanish translator for fixing.
    The problem is that there are lots of them.
    Some parts of the help file are very well translated but others looks like machine translations or they are wrong translated.
    Could you add the English help file to the international installer? When the English language is selected and you try to open the help file then an error appears. (Can not find PowerArchiver Help. Please reinstall PowerArchiver.). It would be good to have the original help file too.
    In the interface there are not only translation bugs. You can see what I mean in the attached screenshots.
    And please, could someone answer to my first post’s question? Thanks and Merry Christmas
    Translations
    Indonesian native language translation…
    Any possible to add Indonesian native speak???
    Translations
    How to translate
    R
    Hello
    I have only one question and this is how to translate power archiver.What do I need to translate wich programs.
    Translations
    Italian translation of PA 2010
    F
    I’m available for translating PA 2010 and its WebSite into ITALIAN.
    Reply me if you are interested.
    Translations
    Pa 2009 italian translation
    Translations
    • F
      FSoft
      If you want I can translate in italian PA 2009.
      Bye!
      • E
        etms51
        yes i will translate into italian language the your program.
        F 1 Reply Last reply Reply Quote 0
        • F
          FSoft @etms51
          How can I translate PA 2009?
          Come posso tradurre PA 2009?
          Bye!
          Ciao!
          • B
            Botta
            Ho visto che è uscita la versione in italiano di PA2009 e ho notato qualche errore di traduzione.
            A chi mi devo rivolgere per segnalare gli errori?
            Ciao
            • B
              Botta @Botta
              Se per caso chi cura la traduzione dovesse leggere questo post queste sono gli errori che ho trovato:
              Utilizzando la Toolbar classica:
              Visualizza –> ad icone (Forse era solo “Icone”)
              Opzioni–>configurazione–>Estensioni di esplora risorse
              la parola “extraction” non è stata tradotta
              nella voce di menu “compressione” c’è scritto comprimi && cifra
              Aggiungi Sottomenu > non si legge completamente basta abbreviare (Agg. Sottomenu o Nel Sottomenu)
              Opzioni–>configurazione–>Temi&Barra strumenti
              La scritta “predefinito” è più lunga della grandezza dei tasti
              Backup–> Crea/modifica
              In opzioni aggiuntive c’è scritto “ZIP(recommandato)” e pure in 7-Zip
              “Filtri Su Data/ora e dimensioni” è troppo lungo e non si legge completamnte(magari basta eliminare “su”)
              Utilizzando l’interfaccia moderna(Linguetta Home):
              Nella sezione “Backup” se si lascia il mouse sopra il tasto “Selezione” esce il piccolo popup dove c’è scritto "Seleizona un backup di PowerArchiver esistente
              Nella sezione “Masterizzatore” se si lascia il mouse sopra il tasto “Disco virtuale” esce il piccolo popup con la scritta non tradotta “Virtual Drive…” e così anche per il tasto “masterizza” la finestra popup ha la parola non tradotta “Burn data”
              Poi c’è la scritta “da Disco a Immagine” per fare le prime lettere tutte uguali o si toglie il “da” oppure lo si fa maiuscolo mettendo minuscolo la parola “Disco”.
              Nella linguetta “Strumenti” la scritta “Masterizzatore” ritorna “Burner”(mistero)
              Utilizzando la visualizzazione delle cartelle in “Stile Esplora Risorse” o “Esplora a cartelle” cliccando all’interno della finestra con il destro e poi su “visualizza” alcuna voci non sono tradotte (icons, Small icons, Lis, Details)
              Un grazie a chi cura la traduzione (sperando che legga questo post)
