    Please publish latest translation templates
    BigMikeB BigMike
    Hi, it would be very kind, if you published the latest translation templates for the current PowerArchiver 2023. So we could complete the translations for the current version. At the moment, at least the Windows 11 context menu and some items in the menus are not translatable at the moment. Kind regards
    Translations
    translations in installer
    guidoG guido
    I downloaded the lastest version and installed it. It started default with “vietnamese”. Strange… I changed trhis to english, but the 3rd stip was not translated [image: 1761035496205-a08345b8-5412-4255-9c58-66f4136ce310-image.png]
    Translations
    Some buttons in "Modern Look" are too small
    BigMikeB BigMike
    Hi, some buttons in Modern Look are too small for German translations. Can you size them dynamically, based on the length of the translation? In some cases the image is also drawn left of the button border and the same for the text on the right: [image: 1552643020529-d6f6eb55-ac72-4de5-a9cf-ba0bd096065a-image.png] By the way, it gets worse in touch mode.
    Translations
    Some Strings in PowerArchiver 2019 are not translatable
    BigMikeB BigMike
    Hi, most of the strings in the SmartAI settings dialog are not translatable at the moment: [image: 1563613492155-a84c75bd-b08b-449e-a71d-c9a1599384a3-image.png] I thought I’d get updated language resources before the release. Will you provide updated language resources in the near future?
    Translations
    %APPNAME% should not contain the version
    BigMikeB BigMike
    In the translation files, there’s the variable %APPNAME% which is replaced by “PowerArchiver 2018”. But the language texts suggest, that it should only be “PowerArchiver”. That’s not really a translation issue, since even the English text is wrong. See the example: [image: 1541336503949-6f968e62-0089-41bb-a38f-ddba2867e9ad-image.png] There’s no “PowerArchiver 2018 9.xx”, the hint should tell me, that I need PowerArchiver 9.xx or later. I found more occurences where “2018” doesn’t fit, mostly in hints. On some occurences (e.g. the window titles) it makes sense, but isn’t really needed.
    Translations
    let's introduce ourselves !
    M mallet
    hi all ! We’ve been working on translations for years, without really being able to put a face on each one of us! Here’s mine! See you soon! Phil, french translator![image: 1527194476789-wp_20171127_15_11_50_pro.jpg]
    Translations
    German Translation
    Z zerone
    Hello, I have found a bad typo in PA 2009 Beta 1: Forschaufenster -> Vorschaufenster –------------------------------------------------- And some word (order) suggestions: Neu Archiv -> Neues Archiv Öffnen Archiv -> Öffne Archiv or Archiv öffnen Verschlüsseln Datei -> Datei verschlüsseln Konvertieren Archiv -> Archiv konvertieren Interface -> Oberfäche (if you translate all words into german, why not interface?) Clear History -> Verlauf löschen And please, clearify “Windows benutzen” -> i know, i use Windows ^^
    Translations
    PA2017 translation issues
    J joakim_46
    [image: pa2017.png] As you can see, the “This product is licensed to:” has not been translated to Portuguese Also the 2nd button has some truncated words, as well the bottom, the C from Correio eletrónico
    Translations
    Danish Translation
    M Mads
    This is a feedback thread for the Danish translation. Please write in Danish. :) Her kan man skrive feedback til den danske oversættelse. Så hvis der er ord, sætninger eller andet, i mener der bør rettes i den danske oversættelse, så er i mere end velkommen til at foreslå dem i denne tråd. /Mads
    Translations
    PowerArchiver 2015 Toolbox License Transfer
    L Lhamo
    Hi, i got a few PA 2015 Toolbox Licenses on hand, so i thought of giving away one of my PA 2015 Toolbox License away, to a good friend of mine, and i will not be using it anymore.;) Could you all please can do it for us, on our behalf.:confused: Thank you very much!:D Best regards.:)
    Translations
    Saying Hello
    M Michealyardy
    Hello to all folks, I am newbie here, just joined this forum site
    Translations
    Polish translation
    K kamil_w
    Hi there, PowerArchiver is great, but I’m really sorry, that there isn’t polish language in the newest version.Is anybody working over polish interface? If not I can do that. Just tell me how.
    Translations
    Errors in Brazilian Portuguese translation
    D dserodio
    The Brazilian Portuguese (pt_BR) translation has lots of typos like missing, duplicated or transposed letters…
    Translations
    Spanish translation
    W Wepver
    @spwolf: nobody in the office knows Spanish well enough, you need to compile issues and we will send it to our Spanish translator for fixing. The problem is that there are lots of them. Some parts of the help file are very well translated but others looks like machine translations or they are wrong translated. Could you add the English help file to the international installer? When the English language is selected and you try to open the help file then an error appears. (Can not find PowerArchiver Help. Please reinstall PowerArchiver.). It would be good to have the original help file too. In the interface there are not only translation bugs. You can see what I mean in the attached screenshots. And please, could someone answer to my first post’s question? Thanks and Merry Christmas [image: attachment_t_4390_0_screenshot.jpg]
    Translations
    Indonesian native language translation…
    W Wandus
    Any possible to add Indonesian native speak???
    Translations
    How to translate
    R rasin
    Hello I have only one question and this is how to translate power archiver.What do I need to translate wich programs.
    Translations
    Italian translation of PA 2010
    F FSoft
    Hello, I’m available for translating PA 2010 and its WebSite into ITALIAN. Reply me if you are interested.
    Translations
    Spanish translation bug
    W Wepver
    “Options/Select Skin/Default Classic”, the “Default Classic” caption is not properly translated. It should say something like “Clásica por defecto”.
    Translations
    Wrong Spanish translation of the compression options
    W Wepver
    The Spanish translation of the compression options is a mess. The first compression method is “Deflación (Compatible) (.zipx)”, English translation : Deflate (Compatible) (.zipx).:confused:
    Translations
    A small Spanish translation issue
    W Wepver
    The “Carpetas favoritas”’s “ncontrar Archivos.” button’s caption should be “Buscar archivos”. The text would fit well in the button and it would be the same translation as the one of the PowerArchiver Help file.
    Translations
    Spanish Translation for PowerArchiver 2007
    Scheduled Pinned Locked Moved Translations
    17 Posts 5 Posters 27.2k Views
    • A Offline
      amm101287
      Hi from Spain!:
      I would like to translate your software into Spanish. I sent an e.mail to support two or three days ago but I did not get a response.
      Could you give me the strings?
        send an email again and refference this post - we have 3 people doing spanish translation right now, but it is quite possible that none will actually complete it… thanks
        • A Offline
          amm101287 @spwolf
          I will not be able to start translating PowerArchiver till the end of June, because I will be taking my university exams that (actually this) month.
          Do I send you the e.mail now or when I’m finish the exams?
          Saludos!!!
          EDIT:
          If you want, I could translate your web page too. I have translated some Ashampoo software, Benvista software, Smartk Install Maker and its web… I only gave up one translation because developers never answer me when I was sending them the translation I made. So, if nothing goes wrong, Spanish translation for PowerArchiver would be ready before September (including the spanish translation for the web) ;)
            check in june and if there isnt an spanish translation on download page, email us… that would be the best.
            thanks.
            A N 2 Replies Last reply Reply Quote 0
            • A Offline
              amm101287 @spwolf
              Hi again!
              If you want, you can send me know the translation files to amm101287@yahoo.es and I could start translating in my free time between the exams.
              Saludos!!!
              • N Offline
                NMarco @spwolf
                thanks.
                why for the spanish translation you reply and for Italian translation you don’t reply?? :D
                  i thought i replied to you - italian translation is being worked on…
                  • A Offline
                    amm101287
                    What about sending me the translation files. I will have two free days (sunday and monday) and I could make progress in PowerArchiver translation or in the web.
                    Which is the method you use to translate the web? Using Dreamweaver?
                    Saludos!!!
                    • B Offline
                      bugfix @spwolf
                      If you need, maybe I can help with the italian translation.
                      Let me know…
                        spwolf conexware @amm101287
                        @amm101287:
                        Saludos!!!
                        can you please email us via support form above and I will send you files?
                          spwolf conexware @bugfix
                          @bugfix:
                          Let me know…
                          not at this time, translator is doing fine so it seems…
                          • B Offline
                            bugfix
                            ok :)
                            • A Offline
                              amm101287 @spwolf
                              Form sent!
                              If you could send the files in minutes I could start translating right now! :rolleyes::rolleyes:;);)
                              Saludos!!!
                                M.A.G. @amm101287
                                This post is deleted!
                                • N Offline
                                  NMarco @M.A.G.
                                  but not in ITALIAN?!!! WHYYYY???
                                    spwolf conexware @NMarco
                                    @NMarco:
                                    italian translation is being worked on as well…
                                    • N Offline
                                      NMarco @spwolf
                                      good news!
