Navigation
    • Include Virtual Drive as standalone in the installer
      Hi.
      I noticed that when I want to run the Virtual Drive for the first time inside the PowerArchiver Burner it prompts to download it form the internet.
      I was wondering, would it be OK to include this utility straight into the offline installer to be able to set it up locally?
      Thank you!
      Wishlist
    • Suggestion to improve .pa format
      Brian Gregory
      Libreoffice/Openoffice ODF documents are all, as far as I am aware, just renamed .zip files. (.odt, .ott, .ods, .ots, .odp, .otp, .odb, .odf etc.)
      Wishlist
    • Folder navigation
      drteeth
      I would like to make a further plea for my mouse’s backwards and forwards keys to work when navigating to and from files, just like they do in explorer. IIRC, I was told that this functionality would be added to v2019.
      Mni tnx.
      Wishlist
    • Quake 1/2 .PAK file support
      AluminumHaste
      I use PA for everything, if I can.
      Would be really nice to maybe get built in support for Quake 1/2 .pak files.
      More info on the format, seems simpler than I thought: https://quakewiki.org/wiki/.pak
      Wishlist
    • Better archive type handling with drag & drop
      BigMike
      So XPI files (Firefox addons) for example are ZIP files. PowerArchiver opens them without any problems, but if I try to add file by drag & drop, PowerArchiver won’t auto select “ZIP”, but use the last selected archive format, while PowerArchiver already knows, that I’m trying to add files to a ZIP.
      Wishlist
    • Find file in archive.
      Luxor
      Reason I ask is that I was looking for a certain file I knew existed in an archive, but I had to unzip it then use another tool to find the file. It would have saved that extra step if that function existed in PA itself.
      Wishlist
    • Encrypt files inside archive that has already been created [.zipx]
      Hi.
      Is there a way to enable the user to encrypt the files inside a ZIPX archive that has already been created?
      This could save time for large archives that the user may need to encrypt at a later stage or that he/she has forgotten to enable encryption before creating the archive,
      Thank you!
      Wishlist
    • Fast Extract large files directly to target directory
      Hi.
      I would like to see a new feature implemented: a ‘Fast Extract’ Mode.
      Currently PowerArchiver extracts files to a temporary directory and then moves them to the target directory chosen by the user. At least via drag and drop.
      This can be both time consuming and needs free space on the system drive for large files.
      Is there a way to directly extract files to the target directory with PowerArchiver?
      And if not, can a feature like this be considered for future updates?
      Thanks very much!
      Wishlist
    • Serpent-256 Encryption for PAE/PAE2
      Hello.
      I believe it would be useful to implement Serpent-256 encryption for PAE/PAE2 formats, even though PowerArchiver offers strong encryption ciphers already.
      (deleted part advertising other software - admin)
      Do you think this will be a useful addition?
      Thank you for the consideration!
      Wishlist
    • Make portable version compatible with PortableApps
      I think it would be a great option to make the portable version of PowerArchiver compatible with PortableApps (i.e. adding the necessary files and folders to integrate it smoothly into their structure).
      I own various other commercial programmes which -when installed in portable mode- offer to make the becessary changes without needing an extra installer or the official PortableApps repos.
      Thanks for opinions or perhaps even a realization of this.
      A.Borque
      Wishlist
    • PBS Filenames
      Presently, PowerArchiver 2019 (any build) cannot rename PBS filenames by single clicking on such entry or right-click menu has no “Rename” feature!
      Hmm, even pressing F2 on selected entry does nothing :(
      Wishlist
    • pCloud
      B
      Can you add support for pCloud? thanks
      Wishlist
    • ownCloud / Nextcloud
      M
      Please add support for ownCloud / Nextcloud, thanks.
      Wishlist
    • Setting to keep X number of backups
      ghendric
      There needs to be a setting for the backup feature to set how many backup files to keep.
      Wishlist
    • auto open first level in folder treeview when archive is opened
      spwolf
      Wishlist
    • I think SVG files should be treated as text files.
      Brian Gregory
      SVG files (scalable vector graphics) seem to be special XML files and therefore when added to .pa archives I think they should be compressed as if they were text files.
      Wishlist
    • Command Line Switch for View Mode
      BigMike
      I had a look at the command line switches, but there are no switches to change the startup mode.
      At the moment, PowerArchiver opens in the last used mode.
      I’d like to have command line switches to influence the startup mode.
      Basically, the aim is:
      Opening PowerArchiver from Start Menu or Desktop: Start in Explorer Mode Opening PowerArchiver by double clicking an archive: Start PowerArchiver in Archive Mode
      Wishlist
    • move back and forth via prev/next buttons in archive/folders
      spwolf
      OT: A while back I requested that moving up and down in an archive’s folder structure could be considered to work with a mouse’s forward and back buttons like windows explorer does. It is so automatic for me I still try to use them with PA first before realising I have to double-click on the two dots. Can this be done?
      by @drteeth
      Wishlist
    • Different Hash Algorithns
      B
      I know CRC32 was the standard for checking the integrity of compressed files but it is not really used anymore. Can you add ones that are used now MD5 or SHA?
      Wishlist
    • Backups files ordering by NAME as default
      pirrbe
      Opening the ‘Backup’ I still wonder how PA is ordering the files.
      It’s not by name, not by last run…
      Is it not possible to have them ordered by NAME (default).
      Now you have to click on Name to have a meaning overview. If you jump to ‘archive’ and back to ‘backup’, they are again disordered
      Thx.
      Wishlist
    Auto detection if PA should use "largeZIP" or not
    Wishlist
    • K
      klumy last edited by
      PA should support auto detection if it should use “make largeZIP 4Gb” option or not.
      So the use needn’t set this setting by himself
      • TBGBe
        TBGBe last edited by
        Did you see this thread
        http://www.powerarchiver.com/forums/showthread.php?t=405
        With the “make large” option checked (active), PA will auto detect!
        The flag is not activated by default for “backward compatibility”.
        That will probably change, soon ?
        • spwolf
          spwolf conexware @TBGBe last edited by
          @TBGBe:
          For 9.5 that option will most likely be turned on at all times and removed from option list…
          • K
            klumy @spwolf last edited by
            great
            this will improve the working with PA
            • spwolf
              spwolf conexware @klumy last edited by
              you can leave it on yourself at all times and it will work the same… It is already enabled in compress to filename.zip in shell extensions.
