    Wishlist
    Wishlist
    create own archive formats for powerarchiver
    Wishlist
    1
    1
    1869
    • S
      splash3313
      I know you can create plugins for powerarchiver but it would be nice to have documentation so we can write our own archive formats to use from within powerarchiver.
