    A ASkripts
    Wishlist
    W Werve
    Wishlist
    2 Votes
    Z ZebraPower
    Wishlist
    PA_FanP PA_Fan
    Wishlist
    C charlesbotz
    Wishlist
    paq9a support
    R richwood
    Wishlist
    Wishlist
    Wishlist
    BigMikeB BigMike
    Wishlist
    OneDrive for Business support
    Z ZebraPower
    Wishlist
    BigMikeB BigMike
    Wishlist
    2 Votes
    A a.borque
    Wishlist
    BigMikeB BigMike
    Wishlist
    F falco99
    Wishlist
    D DaTreeDude
    Wishlist
    2 2Flo
    Wishlist
    Wishlist
    Folder navigation
    drteethD drteeth
    Wishlist
    Quake 1/2 .PAK file support
    AluminumHasteA AluminumHaste
    Wishlist
    Find file in archive.
    Wishlist
    Compression: 32bit or 64bit?
    40 Posts 12 Posters 102.7k Views
      spwolf conexware @gan
      @gan:
      Either way compression is a lot more time consuming so the most important part to improve. If i could pick 64 bit PA to get a bit faster compression, but also a bit slower extraction i would have picked that option.
      I believe 64 bit Windows on the desktop really had a breakthrough with Vista and 7. A lot of people want 64 bit for the OS and then usually prefer native 64 bits applications as well even if they don’t notice a difference compared to 32 bit. I guess it’s not a matter of “if” a software company should have a 64 bit version, but but “when” it should happen since 64 bit obviously is the future. Some competitors are already there and i think PA should consider to do the same thing sooner instead of later.
      -gan
      well this is why the thread was started - to see if people want 64bit extraction of RARs even if it is slower than 32bit extraction of RARs and has no benefit except for being slower :-)
      • G Offline
        gan @spwolf
        Sure i understand and just giving my vote:) But faster compression is a benefit i would say and i assume a 64 bit PA would support the creation of zip, zipx and 7z like the 32 bit edition. The ability to create RARs using PA would be great as well, but that’s another discussion already to be found in other threads.
        -gan
          @gan:
          -gan
          it is possible to use 64bit compression and 32bit extraction for instance (in the same app)
          whole idea that started the thread was that we thought we might add 64bit extraction of rars to PA 32bit, in the case it was faster… so we tested… and tested… and realizied it is not :-).
          PA can not be fully 64bit until there is 64bit version of Delphi (maybe this year), but even then, apparently, it would make sense to actually test if some engine would do better with 32bit version.
          Mixing 32/64bit is more work but if it makes things faster, why not.
            Mameluke @spwolf
            Extraction to me is not as important as compression (Given a reasonable time frame for both). With ISP’s limiting traffic and the rise of cheap online storage, I want to be able to effectively backup things. A smaller file size to me is more important than a little extra time waiting to extract it.
            Mame
              TBGBe @Mameluke
              @Mameluke:
              …A smaller file size to me is more important than a little extra time waiting to extract it.
              If you are talking seconds (or less) then I would agree.
              But if you start needing an extra 10 - 20 mins (for v. large archives) then I would disagree. My point is “real-time” not a percentage change.
              • Z Offline
                zerone
                I don’t think that some (milli)seconds are the problem. Sorry, but i don’t sit while compression/extraction with a stopwatch at the pc. The reason why i would use a 64bit Version is the native support. I believe, when more software works native, software could be more optimized on it. At the moment there is no reason for developer to (or microsoft) optimize the code execution, as long the 32bit software works…
                Ask yourself… would you run on xp a 16bit application if you have a 32bit that do the same?
                • A Offline
                  alextorex @zerone
                  The reason is that I don’t want my Windows to be over-bloated with WOW64 emulation to support old 32 bit code. I prefer all code to migrate to 64 bit and MS to drop emulation.
                  Second reason is that when a developer says he can’t support 64 bit it instantly crosses my mind that he uses outdated IDE and compilers. And this makes me think that probably the whole code (GUI and everything) is not optimized for current multi-core processors and 64bit OS.
                  In Delphi you cannot use for example Intel Parallel Studio to optimize the code for multi core etc. Also Delphi use that over-bloated forms which makes huge executables.
                    all of our code is in C libraries, not delphi… which is why it is faster than WinRar and WinZip, and soon 7zip.
                    IPP is too buggy to be seriously used, but it is good try… we optimize our multicore code manually.
                    Intel has decent idea with primitives and ipp, it is just buggy.
                    • RJWaringR Offline
                      RJWaring
                      On an existing business side of things, its far too expensive and complicated to move everyone onto 64Bit system and OS then upgrade every Application. I work for a group that has over 7300 Employees UK they use Windows XP Pro 32bit and office 2003 SP3.
                      They have a 3 year I.S Plan to move everyone onto Windows 7 32Bit, why not 64bit?? because of known software incompatibilities and Code has to be rewritten from scratch so developers charge more.
                      Keeping PowerArchiver as a 32bit application although its proven better at extracting than 64bit does not stop skeptics from questioning and in many ways slander the application on forum’s, reviews, websites etc all just because it isnt using the more “Modern” 64bit. This in return can cause a domino decline on New Business and increase lapsed sales.
                      On my side of things, and companies i work closely with both inside my group and outside via charities or contracted assignments they all Compress to Send out large documents, images etc etc and also to backup large folder’s on networked drives to then upload to a remote servers via FTP…. All methods the New PowerArchiver now features…
                      SO… Having a program that is 64bit with a 64bit OS that can handle large archives faster is a welcome addition to what already is a great application.
                      My advise to ConeXware…
                      Finish 2011, work on a new website and then come 2013 Anounce “PowerArchiver X64 Toolbox Edition”.
                      I would not do a 64bit Standard Edition, Why? Because I deem 64bit used more by Profesionals that deal with file archiving every day and that would fall under the new Toolbox edition.
                      • G Offline
                        gan @RJWaring
                        @Sir:
                        For large companies upgrade of OS is expensive without any doubt, but i work for a Microsoft gold partner and we have a lot of consultants which is basically what this company is all about. Our experience is that more and more customers are moving to 64 bit OS and one common reason is the 4gb RAM limit with a 32 bit OS. Our company use 64 bit only for the OS. So i would have to disagree when you make it sound like companies won’t move to 64 because it’s too expensive. Yes it’s expensive, but that doesn’t mean it’s too expensive to make this upgrade. I believe it’s just a matter of time before most companies switch to 64 bit and we see that the demand for 64 bit increased a lot since Vista and Windows 7. It will take time before everyone switch, but it’s just a matter of time and it’s not that far into the future i think.
                        I know that a lot of companies are still stuck with 32 bit XP, but that doesn’t mean we should ignore 64 bit Windows since there is a significant marketshare already for Windows 7 x64 and it’s growing. We also know that XP will die in time and 64 bit is the future. New server software from Microsoft is almost only 64 bit for the new versions they release and they started to release 64 bit software for the desktop as well. Many other software companies also started to release 64 bit software so it’s easy to see the trend.
                        I don’t know if most of ConeXware’s customer are companies or not, but i’m under the impression that the advanced home PC users using Windows 7 it’s very common with 64 bit Windows.
                        @Sir:
                        I also have to disagree with this one. Actually the compatiblilty are very good. For almost all of the common software used in companies it will work fine with 64 bit OS. Our company even have consultants working with telecom and old pabx’s and they use a lot of old software that many people probably didn’t think still is being used. That work’s fine as well. There is also an option to use XP mode with Windows 7 as a last resort. With enough RAM and a decent computer that works great. If you also have a SSD which is getting common these days you won’t notice any delay at all using XP mode. Extremly seldom or maybe even never is there a need to rewrite code from scratch for a 32 bit app to work on 64 bit OS. Most often it will just work even if designed for 32 bit and sometimes minor changes. For software that include drivers then 64 bit drivers are needed of course, but the GUI can still be 32 bit.
                        I don’t know your company and what software you use, but unless there are some very good reasons to choose 32 bit i would say that’s a big mistake. My bet is that such a decision will force your company to make the next upgrade sooner than 3 years because the demand for more RAM and other reasons as well. Like i said i don’t know your company, but would be very interested to hear the reasons why you would choose 32 bit when doing such a major upgrade. It would be very interesting to hear what apps that a large part of your company use that won’t work with 64 bit. Also a upgrade from XP to Windows 7 isn’t supported so a new installation have to be done anyway. That would be a good time to make the switch from 32 to 64 bit.
                        @Sir:
                        As i said before in this forum, there are benchmark tests using Winrar x86 and Winrar x64 show the opposite. In that case the x64 edition are faster. I don’t know all the details and i’m not saying that x64 is the best without exceptions in all cases, but i’m just saying that the benchmark from ConeXware differ from other benchmarks. There is no right or wrong here so when ConeXware say that x64 extraction is slower, that’s the fact and everyone saying different are wrong i find that a bit hard to accept. Why Winrar x64 are faster compared to the x86 edition i don’t know. Maybe they managed to do something smart that isn’t possible with 32 bit or maybe they just don’t bother to enhance the x86 version anymore because they believe x64 is the future……i don’t know. I’m just saying that i have never seen a benchmark that says running winrar x86 on a x64 OS will perform faster compared to using winrar x64.
                        @Sir:
                        My advise to ConeXware….
                        I agree that to finish 2011 x86 should be pri 1, but i also think they should be able to release a x64 version in 2012 at the latest. Work on a new website shouldn’t have a higher priority than creating the x64 edition. Hopefully ConeXware can do this in parallel since i’m pretty sure that the people working on the website are not the same as the PA developers. It’s still a cost though.
                        I also have to say that i’m not saying x64 is the best no matter what, but it would be nice if ConeXware where among the first with 64 bit and not the last. Also it seems like a lot of people demand 64 bit for several reasons……and it’s all about selling the products the customers want, right? Customer demand. Even if ConeXware think there is not point it’s more important to ask what do the customers want.
                        I also have to add that PA is probably the fastest or among the fastest when talking about compression/extraction so this part is really good. When talking about the GUI i find PA to be surprisingly slow though. I can launch most other applications like word, excel, Visio, Acrobat and so on faster than PA. So this part is very disappointing. The only app that launch slower on my computer i believe is Photoshop. Even Visual Studio 2010 launch just as fast as PA.
                        -gan
                          Customer feedback is crucial… so yes, we will have to do 64bit version simply because you guys want it and you are the customers afterall.
                          Gan email us at support at conexware dot com… I wonder if PA 2011 is at least noticably faster at startup.
                            (ie we will send you beta)
                            • drteethD Offline
                              drteeth
                              @gan
                              I also understand that there are advantages to using 32 bit apps in a 64 bit OS.
                              DrT
                                davidsplash
                                would like to say stick with 32 bit as you can use this n linux with the windows emulator and most importantly you can use this in reactos operating system
                                • G Offline
                                  gan
                                  I have not been using Powerarchiver for several years for several reasons and figured i should check out the latest release now to see if moving back to powerarchiver would be an option. As far as i can see there are still no 64bit version, is that correct?
                                  I would say that 64bit is no longer the future, but it’s the standard today. I know that some still claim there is no advantage with 64bit, but seems like only those that do not have a 64bit version claim such a thing. All the companies that released 64bit can show benchmarks that show it’s basically faster and better. Some examples are Winrar, Winzip, 7zip, Emeditor and Ultraedit. Some of these are text editors, but Ultraedit is one example that said we do not need 64bit because there is no advantage until they released a 64bit version and it turns out there are several benefits and it’s without doubt faster. If someone claim that 32bit is better it’s strange since everyone else that released 64bit versions already proved the opposite. So why should a single company get another result, is there something wrong with the code or the benchmark or something else?
                                  So did i just miss the 64bit version or do powerarchiver still do not have a 64bit version? Even Winzip created a 64bit version a long time ago.
                                  • drteethD Offline
                                    drteeth
                                    @ gan
                                    That is a very interesting post. I would say that 64 bit is only faster in certain situations and it would be expected that those making 64 bit versions would produce benchmark results that show it. If 64 bit is faster in normal use, I would say that one would not notice it without a stop-watch.
                                    • G Offline
                                      gan
                                      @drteeth
                                      Well i cannot say for sure if they pick the benchmarks that gives the best results for 64bit, but I cannot really see why WinRAR should try to tell everyone 64bit is better since they got both a 32 and 64bit edition. The same goes for Winzip. They measure important stuff like how long it takes to compress and decompress which is the main features of such a program. Ultraedit been getting a lot of complaints because certain operations are slow as well as startup. The 64bit are faster to start and most of these operations now goes faster. If they could make the 32 bit version just as fast then why not since they got both. Emeditor which is my favorite text editor been having a 64bit version for a long time already and it’s been 100% unicode compliant for ages. So they always been in front of the competition which is great for customers. Why the 64bit version are faster in general i don´t know, but i do not have many 32 bits applications left. Do anyone still use a 32 bits OS with the memory limitations that exists in a 32 bit OS? My guess is that a very high percentage of the Windows users that use Windows 7 or newer use the 64 bit edition. OS X is 64 bit and i would be surprised if not most Linux users choose 64 bit as well.
                                      I think it’s time for Powerarchiver to realize that the world is moving on and that 64 bit is no longer the future……it’s now. Seems like the competitors are there so when should PA take the next step as well.
                                      -gan
                                        It probably depends on application and what it does… PA right now probably has the fastest zip engine overall, as tested by various sites… thats with super optimized compression library thats faster than WinZIP’s that is also very fast, has 64bit and even has support for AMD GPU’s, however it is still slower than ours.
                                        It is definitely good marketing though, with PA 2016 coming up, we can finally do 64bit version from technology perspective question is just of priorities since performance measured is little bit faster for compression and a bit slower for extraction. It would take us few months to transfer our zip engine and optimize it so it doesnt end up slower, which would suck… so after 2016, it would be just a question of priorities.
                                        Thanks for updating the thread though, it was fun reading it all over again!
                                        • G Offline
                                          gan
                                          @spwolf
                                          Thank you for your reply. It will be exciting to see the future version of PA and if 64 bit will be a reality :)
                                          -gan
                                          • R Offline
                                            rahul kumar Banned
                                            This post is deleted!
