    FTP User - How to Delete?
    I ItsJustMe
    Sorry for my poor English. It is not my native language. However: My problem / my question: How can you delete a user profile in the FTP part of PowerArchiver? I can create new users only or select them, but i can not delete them. Is the function missing? Or do I overlook something I should see?
    Plugins
    PAOP install silently with settings
    S szacmax
    Hi all, I’m new here, so just a little description for beginning. I’m a french guy who works in Lyon (FRANCE). We wants to install the Power Archiver Outlook Plugin (PAOP) 2013 on our Windows 8. I need to know if there’s a possibility to install the plugin silently with settings. We are using the .msi to install PAOP but we need to set : Minimal filesize : 200 kbytes and Check the box : name based on first attachment Did someone know somethings for that? Maybe by the regedit editor? Thanks a lot PS: sorry for all mistakes in English.
    Plugins
    Libre office plugin
    would like a libre office writter plugin so i can zip streat to zip file or any other archive file that powerarchiver can handle.
    Plugins
    POAP - Adaptive Type Options
    RJWaringR RJWaring
    Hi Team, I use POAP A fair amount and its so good I very rarely notice its actually there. However, for some time I have been wanting to see more options for when Compressing certain files types and to what method and at what level. For example… Currently, PAOP gives me 1 method for all files and if I want have it passworded, also at what point should it auto compress. With all the changes in PowerArchiver 2010 and with 2011 on the way it would be nice to see POAP Follow suite. For example a new feature i would like to see is more custom options to auto compressing file types. ie for Spreadsheets I might want it to auto compress as a non passworded zip after it being over 5 megs. But for Access database files or dat, mdb, bat etc etc I would i would prefer it to use Zipx or 7Zip with Maximum compression after 7 megs. And say I select multiple files including pictures, word documents and websites I would like it to auto zip using another method… and to be clever say I had files in a secure folder called private an ability to tell POAP that anything from that Folder that gets emailed should be encrypted and compressed using PAE with AES with a default password… possibly linked into my Password manager in PowerArchiver 2011… Now this is a fair amount of work but I feel it is an important step forward, taking into consideration how dynamic users files can be. This also could be a Pro Plugin, for an ever so slight charge… And I would be happy to pay!!
    Plugins
    Outlook 2010 and plugin
    T twistedemotions
    Plugin doesn’t even work in 2010… understandable as 2010 moved outlook to the ribbon. I assume this will be fixed, but I thought I’d give a heads up.
    Plugins
    Like to start a plugin contest
    the rules are simple post your plugins here you will be credited with creating for the plugin.
    Plugins
    Outlook Plugin not going away
    L leeirvin
    I have an issue, when I send an e-mail in Outlook, the plug in seems to spawn some sort of orphan process? There’s Outlook Plugin Windows that I can’t get to “restore”. Like, I have Outlook open. Windows reports I have 10 Outlook windows open, but there are really 9 windows labeled “PowerArchiver Outlook Plugin”, none of which respond to being opened. Is there a setting I need to change to avoid this?
    Plugins
    PAOP wishlist
    D deity
    Option: -add each file in separate archive
    Plugins
    PAOP don't work properly
    D deity
    PAOP can’t compress the same files with another names… [image: 3lel.png] [image: hkhhkh.png] [image: 1mem.png] [image: 2mnm.png] why?
    Plugins
    Plugin System
    U UTLonghorns
    I have been researching PowerArchiver to see if it would fit my needs, and have seen many great reviews. I am especially interested in your plugin system, as I use several obscure archivers for which there are TC plugins. I am, however, having a hard time finding info about your plugin system. Is there any documentation about the use of plugins in PA? From the info I have found, some plugins work and some do not, is there any way besides trial and error to determine what type of plugins will work (Multiarc for example)? I have seen the admin on here suggest to a user to write a plugin, but then give no direction or docs as to the format for PowerArchiver plugins. Since TotalCommander plugins do not work all the time, it might well be a waste of time to write a plugin using that format. If a plugin does work, does it just allow viewing or can you compress and extract as well. Does the plugin functionality extend to the context menu? Sorry for the mismash of questions, but the plugin feature really needs better explanation. I would appreciate any info. Thanks, HookEm!
    Plugins
    Plugin version
    it would be nice to see from the about box what plugins and there version are installed.
    Plugins
    Request
    how to create powerarchiver plugins
    Plugins
    Pdf view
    ActivePDFView is a lister plugin (WLX) for Powerarchiver. It allows the user to preview an Adobe Acrobat PDF file in either the QuickView panel or in the floating TC lister window and with much of the utility of the standalone Acrobat viewer. The free Adobe Acrobat Reader must be installed on your system before attempting to use ActivePDFView to view a PDF. http://www.totalcmd.net/plugring/activepdfview.html
    Plugins
    SIS plugin
    plugin that i have tested and works with powerarchiver Opens SIS installation files (Psion, EPOC5 and new also EPOC6). Developed mainly for using with Nokia EPOC5 and EPOC6 packages, but can be used with other types. http://ghisler.fileburst.com/plugins/pdunsis.zip fully tested and works 100%
    Plugins
    Microsoft access plugin
    this allows you to see the structure of a microsft access file and allows you to exhe part you want in csv format ftp://ftp.sac.sk/pub/sac/utilfile/wcx_mdb.zip works and tested 100% on ms acess 2000 and 2003 files
    Plugins
    PowerArchiver Outlook Plug-in
    D deity
    Why in settings absent ultra 7 zip compression?
    Plugins
    Viewer Plugin: SGViewer 1.91 - Awesome!
    SGViewer 1.9.1 Supported formats: BMP; JPEG; PNG; GIF (animation too); TIFF (not all compressions supported); PSD; TGA; PCX; PCD; PSP; EMF; WMF. Features: intelligible interface; easy navigation; full screen view; slideshow; random view mode; antialiasing for fitted images; view animation in GIF; multilingual user interface (English, French, German, Hungarian, Korean, Romanian, Russian, Spanish, Ukrainian); copying, moving, deleting image files; open current image in any application; copy image to and paste from Clipboard; save images to BMP or JPEG; image operations (rotate, mirror, etc.); basic function for print images; support ijl15.dll for fast JPEG load; support libgfl220.dll and libgfle220.dll for JPEG Lossless Transform and thumb’s view TC mode; and many more! Find it here: http://www.totalcmd.net/plugring/sgviewer.html
    Plugins
    Pdf view
    Plugins
    Animated gif plugin
    works 100% tested http://www.saschahlusiak.de/downloads/gifwcx.zip source: http://www.saschahlusiak.de/downloads/gifwcx_source.zip GIFWCX (v1.1): This plugin provides you with the ability to view into animated gif images and extract single frames. “pack” a few single images (*.gif, *.bmp, *.png, *.jpg) to a single animated gif image. append images to existing gif images. delete frames of existing animated gif images.
    Plugins
    Avi plugin
    works 100% tested http://www.saschahlusiak.de/downloads/aviwcx.zip source: http://www.saschahlusiak.de/downloads/aviwcx_source.zip AVIWCX (v1.7): This plugin provides you with the ability to view into AVI Video files and extract frames as bitmap files, and the audio stream of the video as wave file. This is useful i.e. to make shots of a movie. reencode the video with a different video codec by just extracting the videofile, which is offered by the plugin. to encode a bunch of image files to a single AVI Video file. A wave file can be added as audio stream. This is useful if you render a lot of frames of a video, because you can easily encode all of them into a single avi file.
    Plugins
    Plugin System
    Scheduled Pinned Locked Moved Plugins
    6 Posts 5 Posters 29.7k Views
    • U Offline
      UTLonghorns
      Thanks,
      HookEm!
        PA is able to use the “packer” plug-ins from TC (wcx format).
        Sorry, but I know nothing about actually creating them :(
        With the plug-in installed (and file type/format assigned) then the archive files appear as if “natively supported” within the limits of the format (and plug-in). So if that supports viewing, compression, extraction - then so will PA (GUI).
          @UTLonghorns:
          Thanks,
          HookEm!
          packer (extract only) and viewer plugins should always work, unless they use undocumented features… If they dont, someone needs to report it in and we will take an look and fix the issue.
          Viewer plugins work in preview window and internal viewer, while packer plugins work if you open archive inside PowerArchiver (via Open button)… PowerArchiver will not associate itself with any of those supported formats, as in many cases it would be impractical to do so (for instance, with MSI or CHM plugins).
          If you want more features, Wishlist forums is best place for that…
            davidsplash @spwolf
            what everyone is actually asking is how do we create powerarchive plugins
            twphoenixT 1 Reply Last reply Reply Quote 0
            • twphoenixT Offline
              twphoenix @davidsplash
              the Information on How To Create Plugins can be found on the TotalCommanger PluginPage
              http://www.ghisler.com/plugins.htm
              or as Link:
              http://ghisler.fileburst.com/plugins/wcx_ref2.20.zip
              in this Zipfile you will finde the Plugin-Interface Description
              for the Packer-Plugins (WCX)
              the Viewer Plugin Interface is the under Lister Plugins (WLX)
              Best Regards,
              TWPhoenix
                davidsplash @twphoenix
                We already know that is there but nfor people who can’t understand why all total commander plugins don’t work i thought it would be nice to have a program or more advice on how to create powerarchiver plugins.
                Not all plugins work for both powerarchiver and total commander.
                we should have a program that helps you create plugins.
                There should be plugin contests and a way for people to make money on plugins as some do with total commander
