    Wishlist
    Wishlist
    Z
    Wishlist
    PA_FanP
    Wishlist
    Wishlist
    paq9a support
    R
    Wishlist
    Wishlist
    Wishlist
    BigMikeB
    Wishlist
    OneDrive for Business support
    Z
    Wishlist
    BigMikeB
    Wishlist
    Wishlist
    BigMikeB
    Wishlist
    F
    Wishlist
    Wishlist
    Wishlist
    Wishlist
    Folder navigation
    drteethD
    Wishlist
    Quake 1/2 .PAK file support
    AluminumHasteA
    Wishlist
    Find file in archive.
    Wishlist
    Powarc1021rc1
    7 Posts 4 Posters 7.9k Views
      deity
      Please update 7Z.DLL (4.55) to 4.56 and UNRAR3.DLL to 3.71
        davidsplash
        3.71 is the version number of lastest winrar not the latest unrar3
          deity
          http://downloads.sourceforge.net/sevenzip/7z458_extra.7z
          7z.dll - 4.58.10.0
          http://www.rarlab.com/rar/UnRARDLL.exe
          Unrar.dll -3.80.1.87
            i think we already have those in upcoming version
            • skypxS Offline
              skypx @spwolf
              So are we getting close to the new release? :D
              ASUS Crosshair VII Hero
              AMD Ryzen 9 5700X
              T-Force DDR4 3600 32GB
              Samsung 970 EVO 2TB
              GTX 3080ti
              Win10 x64
                spwolf conexware @skypx
                @skypx:
                very.
                • skypxS Offline
                  skypx @spwolf
                  Thanks for the info…. :)
                  AMD Ryzen 9 5700X
                  Samsung 970 EVO 2TB
                  GTX 3080ti
                  Win10 x64
