I know I have been asking for this feature some time ago, but as nothing has changed let me ask again:
The ZIPX-format offers an algorithm, that compresses JPEG-files by about 20-30%. Please add compression (packing) support for this in ZIPX-archives to Powerarchiver. Extraction of JPEGs packed into ZIPX by this algorithm is already supported by Powerarchiver for a long time, so it should not be difficult? Or is it a licensing problem?
Thanks! -
So XPI files (Firefox addons) for example are ZIP files. PowerArchiver opens them without any problems, but if I try to add file by drag & drop, PowerArchiver won’t auto select “ZIP”, but use the last selected archive format, while PowerArchiver already knows, that I’m trying to add files to a ZIP. -
I love this, only there is one problem. The UAC elevation feature does not extend to Mount Image option in the add-on software PA provided. It is most annoying whenever I am on highest UAC settings and I mount an ISO, every time I open and create a virtual drive UAC appears. I also do not want to completely disable UAC.
Is adding UAC elevation for mount image feature possible?
Hi.
I noticed that when I want to run the Virtual Drive for the first time inside the PowerArchiver Burner it prompts to download it form the internet.
I was wondering, would it be OK to include this utility straight into the offline installer to be able to set it up locally?
Thank you!
Libreoffice/Openoffice ODF documents are all, as far as I am aware, just renamed .zip files. (.odt, .ott, .ods, .ots, .odp, .otp, .odb, .odf etc.) -
Reason I ask is that I was looking for a certain file I knew existed in an archive, but I had to unzip it then use another tool to find the file. It would have saved that extra step if that function existed in PA itself. -
Hi.
Is there a way to enable the user to encrypt the files inside a ZIPX archive that has already been created?
This could save time for large archives that the user may need to encrypt at a later stage or that he/she has forgotten to enable encryption before creating the archive,
Thank you!
Hi.
I would like to see a new feature implemented: a ‘Fast Extract’ Mode.
Currently PowerArchiver extracts files to a temporary directory and then moves them to the target directory chosen by the user. At least via drag and drop.
This can be both time consuming and needs free space on the system drive for large files.
Is there a way to directly extract files to the target directory with PowerArchiver?
And if not, can a feature like this be considered for future updates?Thanks very much!
Hello.
I believe it would be useful to implement Serpent-256 encryption for PAE/PAE2 formats, even though PowerArchiver offers strong encryption ciphers already.
(deleted part advertising other software - admin)
Do you think this will be a useful addition?
Thank you for the consideration!
I think it would be a great option to make the portable version of PowerArchiver compatible with PortableApps (i.e. adding the necessary files and folders to integrate it smoothly into their structure).
I own various other commercial programmes which -when installed in portable mode- offer to make the becessary changes without needing an extra installer or the official PortableApps repos.
Thanks for opinions or perhaps even a realization of this.
A.Borque -
Presently, PowerArchiver 2019 (any build) cannot rename PBS filenames by single clicking on such entry or right-click menu has no “Rename” feature!
Hmm, even pressing F2 on selected entry does nothing :(
Please add support for ownCloud / Nextcloud, thanks.
I had a look at the command line switches, but there are no switches to change the startup mode.
At the moment, PowerArchiver opens in the last used mode.
Opening PowerArchiver from Start Menu or Desktop: Start in Explorer Mode Opening PowerArchiver by double clicking an archive: Start PowerArchiver in Archive Mode
I’d like to have command line switches to influence the startup mode.
Basically, the aim is:
Plugins
there is no way from the plugins configurations box to update plugin nor is there a way to know wghich plugin version you have installed when will this be corrected
This post is deleted! -
Good point Davidsplash!
This was something I also noticed! it would also be nice if the update feature in PowerArchiver included plugins and gave the user the option to install them from their main PA console instead of having to go online!
