    B basitbulbulia
    Question Regarding License
    S Skybird
    PACL 9.0 Beta 2
    Michael72M Michael72
    BigMikeB BigMike
    Hi, there’s a problem with PAComp and file names with a leading ".\ ". That’s nowadays a problem, since PowerShell auto complete will complete a file test.zip in the current directory to .\test.zip. [image: 1524826662978-pacomp.png] The first command reports “All OK”, but test.7z is not created. The second command reports an error, but the error message isn’t helpful at all. VSS doesn’t help anything if a program fails to write to a file. It’s for reading locked files… And the problematic file isn’t mentioned at all. By the way, there’s a typo, it should be “open”, not “opet”. Only the third command (without ".\ ") works as expected. The problem exists in the x86 and x64 version, it doesn’t matter if the archive already exists (updating) or not (creating a new archive).
    czip support
    PACL 8.0 Beta 1
    P Prateek kumar
    PAConv.bat
    BigMikeB BigMike
    Profile Details
    B Brazilian
    Pacl 8.0
    How to encrypt file names?
    F farukhsharipov
    B BossHauss
    PACOMP -fips and -e2 commands
    F farukhsharipov
    F farukhsharipov
    F farukhsharipov
    Archive based on age
    O oblivion
    G GOZARCK
    Hi in pacomp.vbs by Micke how to preserve the folders structure of the files to compress.:confused: because just compress the files not the folder structure of each file. thanks '******************************************************************* '* PACOMP.vbs '* @author: Micke '* @hist 2010-02-26 CREATED:Script for compress multiple file types '* @hist 2010-03-01 BUGFIX: Space in path or filename resulted in '* no archive was created. '* '* Script for compress multiple file types '* '* Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath '* Example1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D: '* Example2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp '* '******************************************************************* Option Explicit 'Variables Dim FSO, objDir, aList, FileExtension, ArchiveName, DrivePath Dim aFile, aItem, strCompressionString, WshShell 'Constants (Change path to your own enviroment) Const PACOMP = "C:\Programs\PACL\PACOMP.exe" 'Check number of arguments If WScript.Arguments.Count <> 2 Then WScript.Echo "Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath" WScript.Echo "Example 1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:" WScript.Echo "Example 2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp" WScript.Quit End If 'Create the FileSystemObject Set FSO = CreateObject("Scripting.FileSystemObject") 'Create the ShellObject Set WshShell = CreateObject("WScript.Shell") 'Get data from the Arguments ArchiveName = WScript.Arguments.Item(0) DrivePath = WScript.Arguments.Item(1) 'Get the Folders for the DrivePath Set objDir = FSO.GetFolder(DrivePath) 'Create a Array with Fileextensions for the archive, change to your enviroment aList = Array("png", "jpg", "avi") 'Search through the folders SearchFolders(objDir) 'Sub for Searching recursive in Folders Sub SearchFolders(pstrCurrentPath) For Each aFile In pstrCurrentPath.Files For Each FileExtension In aList If FileExtension = LCase(Right(CStr(aFile.Name), 3)) Then AddFileToArchive aFile.Path End If Next Next For Each aItem In pstrCurrentPath.SubFolders SearchFolders(aItem) Next End Sub Sub AddFileToArchive(pstrFileName) 'Create the string with parameters for PACOMP strCompressionString = PACOMP & " -a -P " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34) WScript.Echo strCompressionString WshShell.Run strCompressionString, 0, True End Sub
    My password
    M mrabdoxxx
    Problem archiving from shares between 4.01 and 6.01
    48 Posts 5 Posters 56.5k Views
    • B Offline
      Badders
      it is drive letter and network share.
      I don’t understand what you mean by this. Can you give me an example?
      Thanks.
      MickeM 1 Reply Last reply Reply Quote 0
      • MickeM Offline
        Micke Alpha Testers @Badders
        Hi!
        This is only my personal rendering of what spwolf wrote, so I may be wrong about this.
        There are two occasions when this would be nice to have as an option
        1. When you have 2 different driveletters with the same path in the list file. Something like this
        P:\PACL_Test\Foldertest\*.*
        Q:\PACL_Test\Foldertest\*.*
        ```Since the path is exactly the same except for the drive letter the result will be the same as we have created using \\<machinename>\<sharename>\
        2) When you have 2 different sharenames with the same path in the list file. Something like this
        \TestPC\Public\PACL_Test\Foldertest*.*
        \TestPC\Install\PACL_Test\Foldertest*.*
        Micke</sharename></machinename>
          Micke, have you tried this in PACL 7.01 Beta?
          How is it there?
          • MickeM Offline
            Micke Alpha Testers @Mili
            @Mili:
            How is it there?
            No I haven’t tested this yet, but I can do some tests of it tonight.
            The version I have is PACL 7.00 b1, but you talk about 7.01 beta. Does this mean there’s a 7.01 beta version avaliable?
            Kind Regards
            Micke
              Sorry, type-o on my end. 7.00b is the only one available.
                ok, so there will be -PP parameter now that will store drive/share names as well.
                • MickeM Offline
                  Micke Alpha Testers
                  This is the result from testing creation of archive using \machinename\sharename.
                  Version tested: PACL 7.00 RC1
                  OS Version: Windows 7 Ent. Ed. 64-bit
                  Content of Listfile_Machine.txt
                  \\192.168.0.19\Public\PACL_Test\*.*
                  \\192.168.0.19\Install\PACL_Test\*.*
                  Then test creation of archive:
                  C:\Programs\NewTest>pacomp -a -r -PP Test_PACOMP_MachineShare.zip @Listfile_Mach
                  ines.txt
                  PowerArchiver Command Line (PACL)              Version 7.00       [Mar 22 2012]
                  Copyright(c) 1998-2012 ConeXware, Inc.  All Rights Reserved.  Shareware Version
                  Remainder: This is unregistered version of PACL. Please register at http://www.p
                  owerarchiver.com
                  Press <enter>to continue.
                  Archive Compression Utility -- ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
                    Internet: http://www.powerarchiver.com  Email: support@conexware.com
                  Archive: C:\Programs\NewTest\Test_PACOMP_MachineShare.zip
                    preparing to compress...
                    adding: \\192.168.0.19\Public\PACL_Test\F1\FILE2.TXT   --> Done. [9%]
                    adding: \\192.168.0.19\Public\PACL_Test\F1\FILE3.TXT   --> Done. [13%]
                    adding: \\192.168.0.19\Public\PACL_Test\F1\FILE1.BAT   --> Done. [19%]
                    adding: \\192.168.0.19\Public\PACL_Test\F2\FILE2.TXT   --> Done. [29%]
                    adding: \\192.168.0.19\Public\PACL_Test\F2\FILE3.TXT   --> Done. [32%]
                    adding: \\192.168.0.19\Public\PACL_Test\F2\FILE1.BAT   --> Done. [38%]
                    adding: \\192.168.0.19\Public\PACL_Test\MANUAL.TXT   --> Done. [48%]
                    adding: \\192.168.0.19\Install\PACL_Test\F2\FILE1.TXT   --> Done. [54%]
                    adding: \\192.168.0.19\Install\PACL_Test\F2\FILE2.BAT   --> Done. [63%]
                    adding: \\192.168.0.19\Install\PACL_Test\F2\AILE3.TXT   --> Done. [67%]
                    adding: \\192.168.0.19\Install\PACL_Test\F2\FILE1.zip   --> Done. [70%]
                    adding: \\192.168.0.19\Install\PACL_Test\F1\FILE3.BAT   --> Done. [74%]
                    adding: \\192.168.0.19\Install\PACL_Test\F1\FILE1.BAT   --> Done. [84%]
                    adding: \\192.168.0.19\Install\PACL_Test\F1\FILE2.TXT   --> Done. [90%]
                    adding: \\192.168.0.19\Install\PACL_Test\MANUAL.TXT   --> Done. [100%]
                  All OK
                  C:\Programs\NewTest></enter>
                  Everything looks normal, now lets the the content of the created archive Test_PACOMP_MachineShare.zip
                  C:\Programs\NewTest>paext -v Test_PACOMP_MachineShare.zip
                  owerarchiver.com
                  Archive Extr.---ZIP,ZIPX,7Z,CAB,LHA,ARJ,RAR,ACE,TAR,GZ,BZ2,UUE,ZOO,B64,YENC,...
                  Archive --> C:\Programs\NewTest\Test_PACOMP_MachineShare.zip [ZIP       ]
                  Name            Length   Method   Ratio      Size      Date & Time      CRC-32
                                   13852    DFLT-N   76%       3384  02-07-2010 01:20:02 84dfe51c
                                    5551    DFLT-N   66%       1915  02-07-2010 01:19:20 cbe8bb0a
                                    8230    DFLT-N   72%       2308  02-07-2010 01:18:18 716a3163
                                    4406    DFLT-N    1%       4377  03-13-2010 20:44:16 e555fa01
                  *Totals   15    142642             69%      44093  03-29-2012 22:04:06
                  Test Result: Success
                  Kind Regards
                  Micke
                  • MickeM Offline
                    Micke Alpha Testers
                    Hello again!
                    Time for the same test again, but instead I will use 2 different network driveletters with the same path except for the driveletter.
                    Content of Listfile_Machines_Drive.txt
                    P:\PACL_Test\*.*
                    Q:\PACL_Test\*.*
                    C:\Programs\NewTest>pacomp -a -r -PP Test_PACOMP_MachineShare_Drive.zip @Listfil
                    owerarchiver.com
                    Archive: C:\Programs\NewTest\Test_PACOMP_MachineShare_Drive.zip
                      adding: P:\PACL_Test\F1\FILE2.TXT   --> Done. [9%]
                      adding: P:\PACL_Test\F1\FILE3.TXT   --> Done. [13%]
                      adding: P:\PACL_Test\F1\FILE1.BAT   --> Done. [19%]
                      adding: P:\PACL_Test\F2\FILE2.TXT   --> Done. [29%]
                      adding: P:\PACL_Test\F2\FILE3.TXT   --> Done. [32%]
                      adding: P:\PACL_Test\F2\FILE1.BAT   --> Done. [38%]
                      adding: P:\PACL_Test\MANUAL.TXT   --> Done. [48%]
                      adding: Q:\PACL_Test\F2\FILE1.TXT   --> Done. [54%]
                      adding: Q:\PACL_Test\F2\FILE2.BAT   --> Done. [63%]
                      adding: Q:\PACL_Test\F2\AILE3.TXT   --> Done. [67%]
                      adding: Q:\PACL_Test\F2\FILE1.zip   --> Done. [70%]
                      adding: Q:\PACL_Test\F1\FILE3.BAT   --> Done. [74%]
                      adding: Q:\PACL_Test\F1\FILE1.BAT   --> Done. [84%]
                      adding: Q:\PACL_Test\F1\FILE2.TXT   --> Done. [90%]
                      adding: Q:\PACL_Test\MANUAL.TXT   --> Done. [100%]
                    All OK
                    Everything looks normal, now lets the the content of the created archive Test_PACOMP_MachineShare_Drive.zip
                    C:\Programs\NewTest>paext -v Test_PACOMP_MachineShare_Drive.zip
                    owerarchiver.com
                    Archive --> C:\Programs\NewTest\Test_PACOMP_MachineShare_Drive.zip [ZIP       ]
                    *Totals   15    142642             70%      43477  03-29-2012 22:15:58
                    Very good work on PACL 7.00. Looks like this is working as expected now.
                    Kind Regards
                    Micke
