    B basitbulbulia
    Question Regarding License
    S Skybird
    PACL 9.0 Beta 2
    Michael72M Michael72
    BigMikeB BigMike
    Hi, there’s a problem with PAComp and file names with a leading ".\ ". That’s nowadays a problem, since PowerShell auto complete will complete a file test.zip in the current directory to .\test.zip. [image: 1524826662978-pacomp.png] The first command reports “All OK”, but test.7z is not created. The second command reports an error, but the error message isn’t helpful at all. VSS doesn’t help anything if a program fails to write to a file. It’s for reading locked files… And the problematic file isn’t mentioned at all. By the way, there’s a typo, it should be “open”, not “opet”. Only the third command (without ".\ ") works as expected. The problem exists in the x86 and x64 version, it doesn’t matter if the archive already exists (updating) or not (creating a new archive).
    czip support
    PACL 8.0 Beta 1
    P Prateek kumar
    PAConv.bat
    BigMikeB BigMike
    Profile Details
    B Brazilian
    Pacl 8.0
    How to encrypt file names?
    F farukhsharipov
    B BossHauss
    PACOMP -fips and -e2 commands
    F farukhsharipov
    F farukhsharipov
    F farukhsharipov
    Archive based on age
    O oblivion
    G GOZARCK
    Hi in pacomp.vbs by Micke how to preserve the folders structure of the files to compress.:confused: because just compress the files not the folder structure of each file. thanks '******************************************************************* '* PACOMP.vbs '* @author: Micke '* @hist 2010-02-26 CREATED:Script for compress multiple file types '* @hist 2010-03-01 BUGFIX: Space in path or filename resulted in '* no archive was created. '* '* Script for compress multiple file types '* '* Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath '* Example1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D: '* Example2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp '* '******************************************************************* Option Explicit 'Variables Dim FSO, objDir, aList, FileExtension, ArchiveName, DrivePath Dim aFile, aItem, strCompressionString, WshShell 'Constants (Change path to your own enviroment) Const PACOMP = "C:\Programs\PACL\PACOMP.exe" 'Check number of arguments If WScript.Arguments.Count <> 2 Then WScript.Echo "Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath" WScript.Echo "Example 1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:" WScript.Echo "Example 2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp" WScript.Quit End If 'Create the FileSystemObject Set FSO = CreateObject("Scripting.FileSystemObject") 'Create the ShellObject Set WshShell = CreateObject("WScript.Shell") 'Get data from the Arguments ArchiveName = WScript.Arguments.Item(0) DrivePath = WScript.Arguments.Item(1) 'Get the Folders for the DrivePath Set objDir = FSO.GetFolder(DrivePath) 'Create a Array with Fileextensions for the archive, change to your enviroment aList = Array("png", "jpg", "avi") 'Search through the folders SearchFolders(objDir) 'Sub for Searching recursive in Folders Sub SearchFolders(pstrCurrentPath) For Each aFile In pstrCurrentPath.Files For Each FileExtension In aList If FileExtension = LCase(Right(CStr(aFile.Name), 3)) Then AddFileToArchive aFile.Path End If Next Next For Each aItem In pstrCurrentPath.SubFolders SearchFolders(aItem) Next End Sub Sub AddFileToArchive(pstrFileName) 'Create the string with parameters for PACOMP strCompressionString = PACOMP & " -a -P " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34) WScript.Echo strCompressionString WshShell.Run strCompressionString, 0, True End Sub
    My password
    M mrabdoxxx
    Problem archiving from shares between 4.01 and 6.01
    48 Posts 5 Posters 56.5k Views
      • MickeM Offline
        Micke Alpha Testers @spwolf
        Hi!
        I’m working on a new script for use with PACL and during the tests of it I discovered some new information regarding the problem described in this thread.
        Hi guys,
        Let me confirm this:
        so there are 2 issues:
        1. You want drive/share included into the path
        2. If we have multiple share paths in list file, it will not work. Only single line works?
        I have tested this with 2 different list files
        List file with one row (Listfile_Singlerow.txt)
        Q:\Dokument\Amiga\*.pcx
        List file with two rows (Listfile_Doublerow.txt)
        R:\Cinemaware\*.adf
        Running the command with single line list row
        Q:\>pacomp -a -p Test_PACOMP_ListSingleRow.zip @Listfile_Singlerow.txt
        PowerArchiver Command Line (PACL)              Version 6.01       [Feb 07 2010]
        Copyright(c) 1999-2010 ConeXware, Inc.  All Rights Reserved. Registered Version
        This product is licensed to:
        Archive Compression Utility -- ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
          Internet: http://www.powerarchiver.com  Email: support@conexware.com
        Archive: Q:\Test_PACOMP_ListSingleRow.zip
          preparing to compress...
          adding: REFSCAN1.PCX   --> Done. [23%]
          adding: REFSCAN2.PCX   --> Done. [41%]
          adding: REFSCAN3.PCX   --> Done. [53%]
          adding: REFSCAN4.PCX   --> Done. [71%]
          adding: REFSCAN5.PCX   --> Done. [89%]
          adding: REFSCAN6.PCX   --> Done. [100%]
        All OK
        Q:\>
        Running the same command with double line list row
        Q:\>pacomp -a -p Test_PACOMP_ListDouble.zip @Listfile_Doublerow.txt
        Archive: Q:\Test_PACOMP_ListDouble.zip
           *** ERROR ():    DefaultDir
           *** WARNING: Nothing to add or update...
        1 error(s) encountered
        Q:\>
        Now if I change the command in PACOMP from -p to -P and run it again with double line list row
        Q:\>pacomp -a -P Test_PACOMP_ListDouble.zip @Listfile_Doublerow.txt
          adding: Dokument\Amiga\REFSCAN1.PCX   --> Done. [0%]
          adding: Dokument\Amiga\REFSCAN2.PCX   --> Done. [1%]
          adding: Dokument\Amiga\REFSCAN3.PCX   --> Done. [1%]
          adding: Dokument\Amiga\REFSCAN4.PCX   --> Done. [2%]
          adding: Dokument\Amiga\REFSCAN5.PCX   --> Done. [2%]
          adding: Dokument\Amiga\REFSCAN6.PCX   --> Done. [3%]
          adding: Cinemaware\ICFTD21.adf   --> Done. [11%]
          adding: Cinemaware\ICFTD22.adf   --> Done. [20%]
          adding: Cinemaware\ICFTD23.adf   --> Done. [29%]
          adding: Cinemaware\it_came_from_the_desert-1.adf   --> Done. [38%]
          adding: Cinemaware\it_came_from_the_desert-2.adf   --> Done. [47%]
          adding: Cinemaware\it_came_from_the_desert-3.adf   --> Done. [55%]
          adding: Cinemaware\Tvbaskt1.adf   --> Done. [64%]
          adding: Cinemaware\TVBASKT2.ADF   --> Done. [73%]
          adding: Cinemaware\tvsportboxing.adf   --> Done. [82%]
          adding: Cinemaware\TVSportsBaseball-1.adf   --> Done. [91%]
          adding: Cinemaware\TVSportsBaseball-2.adf   --> Done. [100%]
        All OK
        Q:\>
        As you can see, the results is now successful. The problem appears when you are using the -p parameter in the command, but if you are using the -P parameter instead, multiple rows in list files works without any problem.
        I haven’t tested this with \<machine><sharename>\ in list files but most likely it will work the same depending on if you use the -P parameter.
        I believe we can remove issue 2 from the list, however I would like to know why it works with -P but not with -p
        Kind Regards
        Micke</sharename></machine>
          p|P : store relative Pathnames|store full Pathnames
          MickeM 1 Reply Last reply Reply Quote 0
          • MickeM Offline
            Yes, I know that, but the error message doesn’t indicate that the parameter p is the problem.
            Maybe this should be mentioned in the documentation of PACL that the command -p in combination with a list file could cause error messages if the list file contains more than one row.
            Kind Regards
            Micke
              spwolf conexware @Micke
              @Micke:
              Kind Regards
              Micke
              but thats an bug ;-)…. so in next update, it will be fixed.
              MickeM 2 Replies Last reply Reply Quote 0
              • MickeM Offline
                Thanks, the reason for bringing this up again was that the first test indicated that there was always error messages when using list files with multiple lines. When I found out that it worked with more than one line by using the P parameter I thought that maybe it wasn’t a bug but incorrect parameter setting.
                Anyway, thanks for the information. Looking forward the next update of PACL
                Kind Regards
                Micke
                • B Offline
                  Badders @Micke
                  I haven’t tested this with \<machine><sharename>\ in list files but most likely it will work the same depending on if you use the -P parameter.</sharename></machine>
                  No it doesn’t - unfortunately.
                  E:\PACL6>ver
                  Microsoft Windows XP [Version 5.1.2600]
                  E:\PACL6>type pacl6prob.lst
                  \\DTTST03\Data\pacltest\*.*
                  \\DTRAH05\Data\pacltest\*.*
                  E:\PACL6>pacomp -a -r -P -k -c2 PACL6prob.zip @PACL6prob.lst
                  This product is licensed to: Decision Systems Ltd
                  Archive: E:\PACL6\PACL6prob.zip
                    adding: pacltest\F1\FILE1.TXT   --> Done. [12%]
                    adding: pacltest\F1\FILE2.TXT   --> Done. [25%]
                    adding: pacltest\F2\FILE3.TXT   --> Done. [37%]
                    adding: pacltest\F2\FILE4.TXT   --> Done. [50%]
                    adding: pacltest\F1\FILE1.TXT   --> Done. [62%]
                    adding: pacltest\F1\FILE2.TXT   --> Done. [75%]
                    adding: pacltest\F2\FILE3.TXT   --> Done. [87%]
                    adding: pacltest\F2\FILE4.TXT   --> Done. [100%]
                  All OK
                  E:\PACL6>paext -t PACL6prob.zip
                  Archive Extr.---ZIP,ZIPX,7Z,CAB,LHA,ARJ,RAR,ACE,TAR,GZ,BZ2,UUE,ZOO,B64,YENC,...
                  Archive --> E:\PACL6\PACL6prob.zip [ZIP]
                    testing: pacltest\F1\FILE1.TXT  --> OK [12%]
                    testing: pacltest\F1\FILE2.TXT  --> OK [25%]
                    testing: pacltest\F2\FILE3.TXT  --> OK [37%]
                    testing: pacltest\F2\FILE4.TXT  --> OK [50%]
                    testing: pacltest\F1\FILE1.TXT  --> OK [62%]
                    testing: pacltest\F1\FILE2.TXT  --> OK [75%]
                    testing: pacltest\F2\FILE3.TXT  --> OK [87%]
                    testing: pacltest\F2\FILE4.TXT  --> OK [100%]
                  E:\PACL6>pause
                  Press any key to continue . . .
                  It doesn’t come up with the ‘*** ERROR (): DefaultDir’ message (as it does with -p) but what you do get, somehow, is duplicate files as shown above.
                  Bug? ;)
                  • MickeM Offline
                    Micke Alpha Testers @Badders
                    @Badders:
                    Bug? ;)
                    My guess is that you have the same directory and file structure in both computer shares. The files will be added to the archive with full path, but the path is the exactly the same on both computer shares.
                    I’ll probably be able to reproduce this when using different drive letters if the path and files is the same on both drives.
                    I have also been successful with use of the -p parameter on multiple line list files on some occasions. I need to do some more tests to see how I can recreate a successful results with the -p parameter and multiple line list files.
                    Kind Regards
                    Micke
                    • MickeM Offline
                      @Badders:
                      I get the same results when I use drive letters in list file.
                      Q:\Dokument\Amiga\*.*
                      R:\Dokument\Amiga\*.*
                      Q:\>pacomp -a -P -r Test_Doublerow.zip @Listfile_Doublerow.txt
                      Archive: Q:\Test_Doublerow.zip
                        adding: Dokument\Amiga\Deluxe Paint 4 Manual.pdf   --> Done. [2%]
                        adding: Dokument\Amiga\REFSCAN1.PCX   --> Done. [4%]
                        adding: Dokument\Amiga\REFSCAN2.PCX   --> Done. [6%]
                        adding: Dokument\Amiga\REFSCAN3.PCX   --> Done. [7%]
                        adding: Dokument\Amiga\REFSCAN4.PCX   --> Done. [9%]
                        adding: Dokument\Amiga\REFSCAN5.PCX   --> Done. [11%]
                        adding: Dokument\Amiga\REFSCAN6.PCX   --> Done. [12%]
                        adding: Dokument\Amiga\Amiga XP x86.pdf   --> Done. [45%]
                        adding: Dokument\Amiga\TF\3Pluto.pcx   --> Done. [46%]
                        adding: Dokument\Amiga\TF\4Goofy.pcx   --> Done. [48%]
                        adding: Dokument\Amiga\TF\5Donald.pcx   --> Done. [49%]
                        adding: Dokument\Amiga\TF\6Daisy.pcx   --> Done. [49%]
                        adding: Dokument\Amiga\TF\3Pluto.pcx   --> Done. [50%]
                        adding: Dokument\Amiga\TF\4Goofy.pcx   --> Done. [52%]
                        adding: Dokument\Amiga\TF\5Donald.pcx   --> Done. [53%]
                        adding: Dokument\Amiga\TF\6Daisy.pcx   --> Done. [54%]
                        adding: Dokument\Amiga\Deluxe Paint 4 Manual.pdf   --> Done. [56%]
                        adding: Dokument\Amiga\REFSCAN1.PCX   --> Done. [58%]
                        adding: Dokument\Amiga\REFSCAN2.PCX   --> Done. [60%]
                        adding: Dokument\Amiga\REFSCAN3.PCX   --> Done. [61%]
                        adding: Dokument\Amiga\REFSCAN4.PCX   --> Done. [63%]
                        adding: Dokument\Amiga\REFSCAN5.PCX   --> Done. [65%]
                        adding: Dokument\Amiga\REFSCAN6.PCX   --> Done. [66%]
                        adding: Dokument\Amiga\Amiga XP x86.pdf   --> Done. [100%]
                      All OK
                      Q:\>paext -t Test_Doublerow.zip
                      Archive --> Q:\Test_Doublerow.zip [ZIP]
                        testing: Dokument\Amiga\Deluxe Paint 4 Manual.pdf  --> OK [2%]
                        testing: Dokument\Amiga\REFSCAN1.PCX  --> OK [4%]
                        testing: Dokument\Amiga\REFSCAN2.PCX  --> OK [6%]
                        testing: Dokument\Amiga\REFSCAN3.PCX  --> OK [7%]
                        testing: Dokument\Amiga\REFSCAN4.PCX  --> OK [9%]
                        testing: Dokument\Amiga\REFSCAN5.PCX  --> OK [11%]
                        testing: Dokument\Amiga\REFSCAN6.PCX  --> OK [12%]
                        testing: Dokument\Amiga\Amiga XP x86.pdf  --> OK [45%]
                        testing: Dokument\Amiga\TF\3Pluto.pcx  --> OK [46%]
                        testing: Dokument\Amiga\TF\4Goofy.pcx  --> OK [48%]
                        testing: Dokument\Amiga\TF\5Donald.pcx  --> OK [49%]
                        testing: Dokument\Amiga\TF\6Daisy.pcx  --> OK [49%]
                        testing: Dokument\Amiga\TF\3Pluto.pcx  --> OK [50%]
                        testing: Dokument\Amiga\TF\4Goofy.pcx  --> OK [52%]
                        testing: Dokument\Amiga\TF\5Donald.pcx  --> OK [53%]
                        testing: Dokument\Amiga\TF\6Daisy.pcx  --> OK [54%]
                        testing: Dokument\Amiga\Deluxe Paint 4 Manual.pdf  --> OK [56%]
                        testing: Dokument\Amiga\REFSCAN1.PCX  --> OK [58%]
                        testing: Dokument\Amiga\REFSCAN2.PCX  --> OK [60%]
                        testing: Dokument\Amiga\REFSCAN3.PCX  --> OK [61%]
                        testing: Dokument\Amiga\REFSCAN4.PCX  --> OK [63%]
                        testing: Dokument\Amiga\REFSCAN5.PCX  --> OK [65%]
                        testing: Dokument\Amiga\REFSCAN6.PCX  --> OK [66%]
                        testing: Dokument\Amiga\Amiga XP x86.pdf  --> OK [100%]
                      Q:\>
                      The duplicate files is logic because the path is exactly the same in both rows except for the drive letter. It’s a bug because obvious nobody have tried using same path and filenames but on different machines and/or drive letters before. :)
                      Kind Regards
                      Micke
                        PACL 6.02 RC:
                        http://www.powerarchiver.com/test/release10/pacl602.exe
                        Please check your reported issues and see if they are fixed or not… thanks!
                        • B Offline
                          Badders
                          OK - I haven’t been able to do as much testing as I would like but the storing of the “\<machine><sharename>” issue isn’t fixed and I can’t see a work around.</sharename></machine>
                          • B Offline
                            Badders
                            Reading back through the thread it looks like this isn’t going to be fixed. I’ll try and do more testing later this week.
                              open up an wish in wishlist thread… it would be some new option to store drive letters and network locations i guess.
                              • MickeM Offline
                                Hi!
                                I have now tested using listfile with 2 rows in it and use the parameter -p (store relative path names). Here’s the result from that test using PACL 6.02
                                Content of Listfile_Doublerow.txt
                                R:\Cinemaware\*.adf
                                ```Create the archive using -p parameter and the created listfile.
                                D:\PACL_Test>pacomp -a -p Test_PACOMP_ListDouble.zip @Listfile_Doublerow.txt
                                PowerArchiver Command Line (PACL) Version 6.02 [Oct 10 2010]
                                Copyright© 1999-2010 ConeXware, Inc. All Rights Reserved. Registered Version
                                Archive Compression Utility – ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
                                Archive: D:\PACL_Test\Test_PACOMP_ListDouble.zip
                                preparing to compress…
                                *** WARNING: Nothing to add or update…
                                D:\PACL_Test>
                                Now with use of parameter -P (Store full path names)
                                D:\PACL_Test>pacomp -a -P Test_PACOMP_ListDouble.zip @Listfile_Doublerow.txt
                                All OK
                                D:\PACL_Test>
                                Test result: **NOT OK**
                                The same error happens with PACL 6.02 as with PACL 6.01
                                Kind Regards
                                Micke
                                • MickeM Offline
                                  Hi!
                                  Just finished testing archiving from shares. Here’s the result from the test of PACL 6.02
                                  Content of Listfile_Machines.txt
                                  \\TestPC\Public\PACL_Test\*.*
                                  \\TestPC\Install\PACL_Test\*.*
                                  ```Create the archive using a listfile
                                  D:\PACL_Test>pacomp -a -r -P Test_PACOMP_MachineShare.zip @Listfile_Machine.txt
                                  Archive: D:\PACL_Test\Test_PACOMP_MachineShare.zip
                                  adding: PACL_Test\F1\FILE2.TXT --> Done. [9%]
                                  adding: PACL_Test\F1\FILE3.TXT --> Done. [13%]
                                  adding: PACL_Test\F1\FILE1.BAT --> Done. [19%]
                                  adding: PACL_Test\F2\FILE2.TXT --> Done. [29%]
                                  adding: PACL_Test\F2\FILE3.TXT --> Done. [32%]
                                  adding: PACL_Test\F2\FILE1.BAT --> Done. [38%]
                                  adding: PACL_Test\MANUAL.TXT --> Done. [48%]
                                  adding: PACL_Test\F2\FILE1.TXT --> Done. [54%]
                                  adding: PACL_Test\F2\FILE2.BAT --> Done. [63%]
                                  adding: PACL_Test\F2\AILE3.TXT --> Done. [67%]
                                  adding: PACL_Test\F2\FILE1.zip --> Done. [70%]
                                  adding: PACL_Test\F1\FILE3.BAT --> Done. [74%]
                                  adding: PACL_Test\F1\FILE1.BAT --> Done. [84%]
                                  adding: PACL_Test\F1\FILE2.TXT --> Done. [90%]
                                  adding: PACL_Test\MANUAL.TXT --> Done. [100%]
                                  All OK
                                  D:\PACL_Test>
                                  List the contents of the created archive
                                  D:\PACL_Test>paext -v Test_PACOMP_MachineShare.zip
                                  Archive Extr.—ZIP,ZIPX,7Z,CAB,LHA,ARJ,RAR,ACE,TAR,GZ,BZ2,UUE,ZOO,B64,YENC,…
                                  Archive --> D:\PACL_Test\Test_PACOMP_MachineShare.zip [ZIP]
                                  Name Length Method Ratio Size Date & Time CRC-32
                                  13852 DFLT-N 76% 3384 02-07-2010 01:20:02 84dfe51c
                                  5551 DFLT-N 66% 1915 02-07-2010 01:19:20 cbe8bb0a
                                  8230 DFLT-N 72% 2308 02-07-2010 01:18:18 716a3163
                                  4406 DFLT-N 1% 4377 03-13-2010 20:44:16 e555fa01
                                  *Totals 15 142642 70% 43387 10-19-2010 21:56:00
                                  D:\PACL_Test>
                                  The result is the same as with 6.01\. I don't know if there's a option for storing \\machine\sharename in the path when creating a archive like this.
                                  Kind Regards
                                  Micke
                                  • B Offline
                                    Badders
                                    Thanks Micke for your excellent analysis - you beat me to it :)
                                      so compressing from network shares works, but it doesnt save share name?
                                      • MickeM Offline
                                        That’s correct. From what I can see PACL 6.02 behave and stores the path exactly the same as PACL 6.01.
                                        Now usually this is not a problem as long as the paths are different in the list file. In these test only the sharename is different resulting in a problem when the rest of the path is exactly the same.
                                        Personally I would like to have a parameter when using PACOMP that says store the <machinename>\ <sharename>in the path when creating archive. If the parameter isn’t used, then the result would be as it is now without storing <machinename>\ <sharename>in the path.
                                        Kind Regards
                                        Micke</sharename></machinename></sharename></machinename>
                                        • B Offline
                                          Badders
                                          Couldn’t you just treat the <machinename>and <sharename>as folders when in the zip? That way you wouldn’t need a parameter and would be compatible with all archive types. That would be cleaner.</sharename></machinename>
                                            thats how it is usually done - as part of the path, but it should be optional since not everyone wants to have it… it is drive letter and network share.
