    B
    Question Regarding License
    S
    PACL 9.0 Beta 2
    Michael72M
    BigMikeB
    czip support
    PACL 8.0 Beta 1
    P
    PAConv.bat
    BigMikeB
    Profile Details
    B
    Pacl 8.0
    How to encrypt file names?
    F
    B
    PACOMP -fips and -e2 commands
    F
    F
    F
    Archive based on age
    O
    G
    Hi in pacomp.vbs by Micke how to preserve the folders structure of the files to compress.:confused: because just compress the files not the folder structure of each file. thanks '******************************************************************* '* PACOMP.vbs '* @author: Micke '* @hist 2010-02-26 CREATED:Script for compress multiple file types '* @hist 2010-03-01 BUGFIX: Space in path or filename resulted in '* no archive was created. '* '* Script for compress multiple file types '* '* Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath '* Example1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D: '* Example2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp '* '******************************************************************* Option Explicit 'Variables Dim FSO, objDir, aList, FileExtension, ArchiveName, DrivePath Dim aFile, aItem, strCompressionString, WshShell 'Constants (Change path to your own enviroment) Const PACOMP = "C:\Programs\PACL\PACOMP.exe" 'Check number of arguments If WScript.Arguments.Count <> 2 Then WScript.Echo "Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath" WScript.Echo "Example 1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:" WScript.Echo "Example 2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp" WScript.Quit End If 'Create the FileSystemObject Set FSO = CreateObject("Scripting.FileSystemObject") 'Create the ShellObject Set WshShell = CreateObject("WScript.Shell") 'Get data from the Arguments ArchiveName = WScript.Arguments.Item(0) DrivePath = WScript.Arguments.Item(1) 'Get the Folders for the DrivePath Set objDir = FSO.GetFolder(DrivePath) 'Create a Array with Fileextensions for the archive, change to your enviroment aList = Array("png", "jpg", "avi") 'Search through the folders SearchFolders(objDir) 'Sub for Searching recursive in Folders Sub SearchFolders(pstrCurrentPath) For Each aFile In pstrCurrentPath.Files For Each FileExtension In aList If FileExtension = LCase(Right(CStr(aFile.Name), 3)) Then AddFileToArchive aFile.Path End If Next Next For Each aItem In pstrCurrentPath.SubFolders SearchFolders(aItem) Next End Sub Sub AddFileToArchive(pstrFileName) 'Create the string with parameters for PACOMP strCompressionString = PACOMP & " -a -P " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34) WScript.Echo strCompressionString WshShell.Run strCompressionString, 0, True End Sub
    My password
    M
    6 Posts 4 Posters 16.5k Views
    • B Offline
      BossHauss
        We will test this out, 2-3 days ago someone reported an issue with large 7zip spanned archives…. thanks.
        • B Offline
          BossHauss @spwolf
          I should have given you more information in my first post, so I’ll try to do that here.
          I have a batch script that includes the following command:
          pacomp -a -P -g -cz -ca -$“%TEMP%” -v%CHUNKSZ% -x@%EXCFILE% -l"%BULOG%\PA_%MON%%DAY%%TM%Log.txt" "%BUTEMP%%MON%%DAY%%TM%.7z" @"%SCRIPTPATH%%BULOG%%MON%%DAY%_%TM%.txt"
          The same command with the variables defined appears as (example):
          pacomp -a -P -g -cz -ca -$C:\WINDOWS\Temp -v100M -x@exclude.txt -l"BackupLogs\PA_12_03_0453PM_Log.txt" “Z:\BackupTemp\12_03_0453PM.7z” @C:\Users\User\Documents\SystemScripts\BackupLogs\12_03_0453PM.txt"
          During the testing of this command, I did not specify any encryption. The archive files were going to be encrypted by Windows native CIPHER (EFS), and then copied to another host using ROBOCOPY /EFSRAW.
          The @list argument at the end of the command line is a text file that is generated with other tools throughout the day. It’s essentially a file that contains a list of thousands of lines, each line a fully defined path name without quotes. For example, one entry in the list would be:
          C:\Users\User ABC From Unit 123\Documents\FileName.pdf
          I also tried:
          pacomp -a -P -v50M
          pacomp -a -v100M
          pacomp -c2 -P -v100M
          pacomp -a -P -g -v100M
          pacomp -a -P -g -c2 -e2 -v100M
          In each case, PACOMP would run for about twenty minutes, using all the CPU it could, then either terminate without any error, or produce a generic error that I didn’t write down and terminate. In every case, it never created any archive files. The only thing it created was most of the header of the log file.
          I then tried to use PA 2013 Pro to do the same thing to see if it would work. From the Home tab, I created a New archive with the following options:
          Type: 7-zip
          Action: Add
          Method: Optimize
          Compression: Maximum
          Encryption: AES 256
          Encrypt Filenames: Yes
          File Paths: Store Full Paths
          Include Subfolders: Yes
          Include System and Hidden Files: No
          Create Solid Archive: Yes
          Encrypt Archive: No
          Multiple Disk Spanning: Custom
          Volume Size: 100000
          VSCS: Smart
          I selected the same folders for archiving as was specified for PACOMP. The amount of data this represents is about 50 gigabytes. PA Pro ran for about an hour, and it produced 256 (.000-.255 - interesting coincidence, or is this a limit?) volumes and completed successfully. However, when I attempted to open the archive, PA Pro indicated that it could not open the file because it was invalid or something like that. Again, I didn’t write it down.
          This is from my memory, so it might not be perfectly accurate. If there’s any testing or diagnostic information you would like me to provide, just let me know.
          Oh, and I’m running this on Windows 8.1 Professional 64-bit.
            We were able to confirm this issue and it has been logged in.
            Thanks for the details :)
            • A Offline
              adrianyujs @Mili
              Latest version v8 Beta 1 can do the job!
                spwolf conexware @adrianyujs
                @adrianyujs:
                let us know if you find anything else. Thanks!
