    B
    Question Regarding License
    S
    PACL 9.0 Beta 2
    Michael72M
    BigMikeB
    czip support
    PACL 8.0 Beta 1
    P
    PAConv.bat
    BigMikeB
    Profile Details
    B
    Pacl 8.0
    How to encrypt file names?
    F
    B
    PACOMP -fips and -e2 commands
    F
    F
    F
    Archive based on age
    O
    G
    Hi in pacomp.vbs by Micke how to preserve the folders structure of the files to compress.:confused: because just compress the files not the folder structure of each file. thanks '******************************************************************* '* PACOMP.vbs '* @author: Micke '* @hist 2010-02-26 CREATED:Script for compress multiple file types '* @hist 2010-03-01 BUGFIX: Space in path or filename resulted in '* no archive was created. '* '* Script for compress multiple file types '* '* Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath '* Example1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D: '* Example2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp '* '******************************************************************* Option Explicit 'Variables Dim FSO, objDir, aList, FileExtension, ArchiveName, DrivePath Dim aFile, aItem, strCompressionString, WshShell 'Constants (Change path to your own enviroment) Const PACOMP = "C:\Programs\PACL\PACOMP.exe" 'Check number of arguments If WScript.Arguments.Count <> 2 Then WScript.Echo "Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath" WScript.Echo "Example 1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:" WScript.Echo "Example 2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp" WScript.Quit End If 'Create the FileSystemObject Set FSO = CreateObject("Scripting.FileSystemObject") 'Create the ShellObject Set WshShell = CreateObject("WScript.Shell") 'Get data from the Arguments ArchiveName = WScript.Arguments.Item(0) DrivePath = WScript.Arguments.Item(1) 'Get the Folders for the DrivePath Set objDir = FSO.GetFolder(DrivePath) 'Create a Array with Fileextensions for the archive, change to your enviroment aList = Array("png", "jpg", "avi") 'Search through the folders SearchFolders(objDir) 'Sub for Searching recursive in Folders Sub SearchFolders(pstrCurrentPath) For Each aFile In pstrCurrentPath.Files For Each FileExtension In aList If FileExtension = LCase(Right(CStr(aFile.Name), 3)) Then AddFileToArchive aFile.Path End If Next Next For Each aItem In pstrCurrentPath.SubFolders SearchFolders(aItem) Next End Sub Sub AddFileToArchive(pstrFileName) 'Create the string with parameters for PACOMP strCompressionString = PACOMP & " -a -P " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34) WScript.Echo strCompressionString WshShell.Run strCompressionString, 0, True End Sub
    My password
    M
    WinXP and Volume Shadow Copy
    3 Posts 2 Posters 7.8k Views
      mixmax
      We use pacl 6.0.1 . On Windows7 we can pack files ntuser.dat
      with volume shadow copy of active user. But this is not possible
      on Windows XP. Volume Shadow service is active.
      How can I backup active files ?
        PACL 6.0.1 does not support VSS, new 7.0 beta does.
          mixmax @spwolf
          I tried to pack active files ntuser.dat and ntuser.dat.log, but
          it doesnt do it, also as administrator.
          D:\test>pacomp -uvss -a -w -k -r -p -c2 d:\test\arch-admin.zip “c:\Dokumente und Einstellungen\administrator\ntu*”
          PowerArchiver Command Line (PACL) Version 7.00 [Mar 22 2012]
          Copyright© 1998-2012 ConeXware, Inc. All Rights Reserved. Shareware Version
          Remainder: This is unregistered version of PACL. Please register at http://www.powerarchiver.com
          Press <enter>to continue.
          Archive Compression Utility – ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
          Internet: http://www.powerarchiver.com Email: support@conexware.com
          Archive: d:\test\arch-admin.zip
          preparing to compress…
          adding: NTUSER.DAT --> Done. [0%]
          adding: NTUSER.DAT.LOG –> Done. [0%]
          adding: ntuser.ini –> Done. [0%]
          adding: ntuser.pol –> Done. [0%]
          All OK
          But result file only contains ntuser.ini and ntuser.pol</enter>
