    Option
    S Socrates
    It would be nice to be able to set more options within individual ZTE – in particular: a) the number of times the file can be downloaded and b) how long it will stay on AC. I have settings I normally use, set in the ZTE options dialogue. These work for 95% of my emails. To change the settings for a single email (which I want to do every week or so), I have to change the settings, send that one email, and then change the configuration settings back to MY defaults.
    Wishlist
    PAE and SFX
    S Socrates
    Is this a realistic possibility?
    Wishlist
    Size does matter
    S Socrates
    A long time request. If someone sends files via ZTE, and has the minimum size set to 15K, then if the person send 200 14K messages, none of them will be compressed. Let the size be determine by the size of the entire archive, not each individual file within said archive.
    Wishlist
    Duplicate notifications again
    S Socrates
    For a while this was fixed . . . Now AC is sending two notifications (an hour or so apart) for each download.
    Wishlist
    Version question AND 2 wishes
    S Socrates
    The version question. Online it says we can download version .25. But when I install it, it says I have version .23 – dated from 9/12. Is that right? Have there been no changes to ZTE in 11 months? The wishes? 1. When someone downloads and installs the latest version, it would be nice NOT to have to re-enter the username (email) and PW. 2. Any chance ZTE could import the FTP profiles from PA – rather than the user having to reenter them?
    Wishlist
    Date and time as filename, would be nice.
    P PALarsen
    Hi. As it is now, we have 2 possible way to get an archive named when using zipped/FTP/Mailed, attachment.XXX or base on first attachment. It would be really nice, if ZTE had an option, to make date+time the filename example.“07 june 2012” + “12:12:59” would be 070612121259.xxx or something like it. Sorry for my bad English, I hope you get the idea :)
    Wishlist
    Encrypt filenames in default, would be nice.
    P PALarsen
    As it is now, I have to invoke zip with options, to use “encrypt filenames” it would be nice if that was an option I could set in the default option page, so all I had to do was invoke “to ZIP+FTP+EMAIL” so the package would be encrypted with password and filename encryption too.
    Wishlist
    If
    S Socrates
    If you are going to keep ZTE as a standalone option, I have one request: Give the user the option of send it as a compressed attachment or as an item in the attachment cloud. I realize you can already do the first if you just use PA (and not ZTE). But it seems that this would be a nice addition.
    Wishlist
    Add SFX option
    S Socrates
    It would be nice to add an SFX option in ZTE.
    Wishlist
    ZTE - FTP & Cloud Option
    RJWaringR RJWaring
    Hi Guys, two options that arnt available are; FTP & Cloud FTP & Cloud & email You may ask! “why would you want to store the file on cloud & FTP??” And I will answer you with If i were sending a file to a customer who wasnt on my business network FTP but also wanted it available to fellow collegues permentaly within the network then i could. So Dear All, Find attached the updated master model PA.XLS external users outside of this buisness network can download via AttachmentCloud this will remain available for 7 days. Conexware employees who require to access this file now including any future updates made please access FTP.Conexware.com and login using your details. Thank you
    Wishlist
    Merge ZTE Shell options with PA's
    K KarbonKopy
    Would be cool if ZTE detects that PA is installed you could manage it from PA perhaps…or add its shell options to PA’s as a one stop shop. :)
    Wishlist
    Default FTP profile ZTE
    K KarbonKopy
    Would be cool to see a option to select a certain FTP profile as the default so you don’t need to select which profile to use when uploading.
    Wishlist
    Test button for ftp settings
    K KarbonKopy
    Looks like that did the trick! One thing, I did noticed I entered the FTP info a bit wrong also, perhaps ZTE should check the FTP profile if one is created to see if it can connect? It gave me no errors so I didnt know until I was double checking. Possible maybe a green light or red light next to the profile or something. Anyhow…thanks!
    Wishlist
    FTP to work in ZTE Outlook
    K KarbonKopy
    Trying to upload and send via customized FTP and not seeming to get it to work yet. Working on it Update: No luck yet it just seems to zip the files and deliver them that way.
    Wishlist
    10 Posts 3 Posters 17.7k Views
    • K Offline
      KarbonKopy
        @KarbonKopy:
        ok, so how did you use it, through shell or through outlook?
        • K Offline
          KarbonKopy
          I am using it from Outlook. I configured the options from the start menu, then fired up Outlook and added attachments then sent the email. Didn’t see an option to select to send over FTP or not in the client, but its an alpha so there might not be :)
            spwolf conexware @KarbonKopy
            @KarbonKopy:
            check configuration in ZTE tab in outlook… there is ftp option there and you can configure it.
            i missed where you said you already did :-).
              ivan conexware
              ZIP + FTP + e-MAIL
              and
              FTP + e-MAIL
              features are available only from shell at the moment.
              From Outlook you have pure ZIP, ZIP + AttachmentCloud or pure AttachmentCloud.
              • K Offline
                KarbonKopy
                Yeah checked it right now and its all setup properly as far as I know with the proper info. Its possible I missed a configuration in order to tell it to send over FTP but I don’t think I have. Here is a cap of my config window minus some of the info hopefully it helps.
                http://www.blackcombco.com/download/zte1.png
                  try via shell and see what happens there… probably one of the latest changes broke ftp in ZTE
                  • K Offline
                    KarbonKopy
                    Ahhhhha! Ill try that and see what it does. Later on it would be cool if you have PA as well to see them kinda integrate with each other if it detects PA installed. Cant wait to keep trying this!
                      spwolf conexware @ivan
                      @ivan:
                      ZIP + FTP + e-MAIL
                      and
                      FTP + e-MAIL
                      well there you go :-).
                      I am sure we can add it to the next beta though.
                        ivan conexware
                        From next release FTP will be available through Outlook too.
                        Also you will be able to specify default FTP profile in Configuration, and default profile will be used for all FTP operations (shell, Outlook)…
