    Option
    S Socrates
    It would be nice to be able to set more options within individual ZTE – in particular: a) the number of times the file can be downloaded and b) how long it will stay on AC. I have settings I normally use, set in the ZTE options dialogue. These work for 95% of my emails. To change the settings for a single email (which I want to do every week or so), I have to change the settings, send that one email, and then change the configuration settings back to MY defaults.
    Wishlist
    PAE and SFX
    S Socrates
    Is this a realistic possibility?
    Wishlist
    Size does matter
    S Socrates
    A long time request. If someone sends files via ZTE, and has the minimum size set to 15K, then if the person send 200 14K messages, none of them will be compressed. Let the size be determine by the size of the entire archive, not each individual file within said archive.
    Wishlist
    Duplicate notifications again
    S Socrates
    For a while this was fixed . . . Now AC is sending two notifications (an hour or so apart) for each download.
    Wishlist
    Version question AND 2 wishes
    S Socrates
    The version question. Online it says we can download version .25. But when I install it, it says I have version .23 – dated from 9/12. Is that right? Have there been no changes to ZTE in 11 months? The wishes? 1. When someone downloads and installs the latest version, it would be nice NOT to have to re-enter the username (email) and PW. 2. Any chance ZTE could import the FTP profiles from PA – rather than the user having to reenter them?
    Wishlist
    Date and time as filename, would be nice.
    P PALarsen
    Hi. As it is now, we have 2 possible way to get an archive named when using zipped/FTP/Mailed, attachment.XXX or base on first attachment. It would be really nice, if ZTE had an option, to make date+time the filename example.“07 june 2012” + “12:12:59” would be 070612121259.xxx or something like it. Sorry for my bad English, I hope you get the idea :)
    Wishlist
    Encrypt filenames in default, would be nice.
    P PALarsen
    As it is now, I have to invoke zip with options, to use “encrypt filenames” it would be nice if that was an option I could set in the default option page, so all I had to do was invoke “to ZIP+FTP+EMAIL” so the package would be encrypted with password and filename encryption too.
    Wishlist
    If
    S Socrates
    If you are going to keep ZTE as a standalone option, I have one request: Give the user the option of send it as a compressed attachment or as an item in the attachment cloud. I realize you can already do the first if you just use PA (and not ZTE). But it seems that this would be a nice addition.
    Wishlist
    Add SFX option
    S Socrates
    It would be nice to add an SFX option in ZTE.
    Wishlist
    ZTE - FTP & Cloud Option
    RJWaringR RJWaring
    Hi Guys, two options that arnt available are; FTP & Cloud FTP & Cloud & email You may ask! “why would you want to store the file on cloud & FTP??” And I will answer you with If i were sending a file to a customer who wasnt on my business network FTP but also wanted it available to fellow collegues permentaly within the network then i could. So Dear All, Find attached the updated master model PA.XLS external users outside of this buisness network can download via AttachmentCloud this will remain available for 7 days. Conexware employees who require to access this file now including any future updates made please access FTP.Conexware.com and login using your details. Thank you
    Wishlist
    Merge ZTE Shell options with PA's
    K KarbonKopy
    Would be cool if ZTE detects that PA is installed you could manage it from PA perhaps…or add its shell options to PA’s as a one stop shop. :)
    Wishlist
    Default FTP profile ZTE
    K KarbonKopy
    Would be cool to see a option to select a certain FTP profile as the default so you don’t need to select which profile to use when uploading.
    Wishlist
    Test button for ftp settings
    K KarbonKopy
    Looks like that did the trick! One thing, I did noticed I entered the FTP info a bit wrong also, perhaps ZTE should check the FTP profile if one is created to see if it can connect? It gave me no errors so I didnt know until I was double checking. Possible maybe a green light or red light next to the profile or something. Anyhow…thanks!
    Wishlist
    FTP to work in ZTE Outlook
    K KarbonKopy
    Trying to upload and send via customized FTP and not seeming to get it to work yet. Working on it Update: No luck yet it just seems to zip the files and deliver them that way.
    Wishlist
    7 Posts 4 Posters 14.5k Views
    • K Offline
      KarbonKopy
      • moles42M Offline
        moles42 Alpha Testers
        actually that very same thought crossed my mind earlier in the week…glad you suggested it though…:)
        Windows 10 Pro x64
        Intel Core i5 3470 @ 3.20GHz
        8.00GB Dual-Channel DDR3
          for FTP, we could use same settings to store FTP servers, while default one would be separate setting.
          • RJWaringR Offline
            RJWaring
            I just downloaded the latest version and to be honest thought about this when ZTE 1st came out.
            Can I suggest that “IF” a user has “PowerArchiver” installed on their system an option either within PowerArchivers or ZTE’s Configuration tab under the typical Shell Extensions tab called “Intergrate ZTE Shell Extensions into PowerArchiver”
            This makes some file and registry updates so ZTE’s shells can be customised, split by features and altered all within PowerArchiver.
            This means as a user i can make all the changes i need within the Main PowerArchiver Application without having to open Outlook.
            Again, a simple tick box and some minor setup changes during install to enable this intergration into a core Conexware application.
            :) i shall say it again “simple”, and wait for you to spit in my tea.
              you can work with Zip to Email options without going to Outlook :-).
              1. There is Options shell extensions that when clicked, takes you to Options :-).
              2. There is separate ZTE Options shortcut in Start Menu.
              moles42M 1 Reply Last reply Reply Quote 0
              • moles42M Offline
                moles42 Alpha Testers @spwolf
                Windows 10 Pro x64
                • RJWaringR Offline
                  RJWaring
                  Still doesnt integrate it into PowerArchiver’s shell extensions :) which is what i want if I own PowerArchiver & ZTE.
                  but its nice to know there is a simple config screen in start menu. However… As a powerarchiver user i have PA Starter and when i want to change anything i just double click through to that which is quicker.
                  I use powerarchiver now for FTP, Archive’s, Burning, Backups, mounting virtual drives and to most part “encryption” all these settings are in that one screen.
                  When ZTE is made available, it would be nice to have that integration so i can change all ConeXware tools into it’s flagship program being “PowerArchiver”
                  Another thing to consider is setting up ZTE to use PA Starter! regardless if the user has PowerArchiver or not because starter is a handly little side app to have.
                  Simple options like;
                  Zip to Email 2011
                  -> Configuration
                  -> Transfer Log (history of emails, FTP’s, Clouds sent using ZTE! With Date, Time etc)
                  -> Login to Attachment Cloud (via website portal)
                  Ow… and i will ask this again, i did make this a request earlier on…
                  If I have PowerArchiver and FTP Profiles setup already, can you please make them available when installing ZTE.
                  So this “integrate ZTE Settings into PA” Would help accomidate this. you could expand on this so;
                  Integrate ZTE Settings into PA, followed by tick boxe’s;
                  1. FTP Profiles
                  2. Shell Extensions & Splits
                  3. Patchbeam (use same settings as PA)
