    B
    Question Regarding License
    S
    PACL 9.0 Beta 2
    Michael72M
    BigMikeB
    czip support
    PACL 8.0 Beta 1
    P
    PAConv.bat
    BigMikeB
    Profile Details
    B
    Pacl 8.0
    How to encrypt file names?
    F
    B
    PACOMP -fips and -e2 commands
    F
    F
    F
    Archive based on age
    O
    G
    Hi in pacomp.vbs by Micke how to preserve the folders structure of the files to compress.:confused: because just compress the files not the folder structure of each file. thanks '******************************************************************* '* PACOMP.vbs '* @author: Micke '* @hist 2010-02-26 CREATED:Script for compress multiple file types '* @hist 2010-03-01 BUGFIX: Space in path or filename resulted in '* no archive was created. '* '* Script for compress multiple file types '* '* Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath '* Example1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D: '* Example2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp '* '******************************************************************* Option Explicit 'Variables Dim FSO, objDir, aList, FileExtension, ArchiveName, DrivePath Dim aFile, aItem, strCompressionString, WshShell 'Constants (Change path to your own enviroment) Const PACOMP = "C:\Programs\PACL\PACOMP.exe" 'Check number of arguments If WScript.Arguments.Count <> 2 Then WScript.Echo "Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath" WScript.Echo "Example 1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:" WScript.Echo "Example 2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp" WScript.Quit End If 'Create the FileSystemObject Set FSO = CreateObject("Scripting.FileSystemObject") 'Create the ShellObject Set WshShell = CreateObject("WScript.Shell") 'Get data from the Arguments ArchiveName = WScript.Arguments.Item(0) DrivePath = WScript.Arguments.Item(1) 'Get the Folders for the DrivePath Set objDir = FSO.GetFolder(DrivePath) 'Create a Array with Fileextensions for the archive, change to your enviroment aList = Array("png", "jpg", "avi") 'Search through the folders SearchFolders(objDir) 'Sub for Searching recursive in Folders Sub SearchFolders(pstrCurrentPath) For Each aFile In pstrCurrentPath.Files For Each FileExtension In aList If FileExtension = LCase(Right(CStr(aFile.Name), 3)) Then AddFileToArchive aFile.Path End If Next Next For Each aItem In pstrCurrentPath.SubFolders SearchFolders(aItem) Next End Sub Sub AddFileToArchive(pstrFileName) 'Create the string with parameters for PACOMP strCompressionString = PACOMP & " -a -P " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34) WScript.Echo strCompressionString WshShell.Run strCompressionString, 0, True End Sub
    My password
    M
    Problem with PACL 4.01 running under 64Bit
    2 Posts 2 Posters 11.8k Views
    • L Offline
      luedt
      Hello everybody,
      I have a problem with PACL v4.01.
      Sometimes when I decrypt .tar.gz files, PACL just hang on. There is only one .txt file included in the archive what I want to decrypt.
      I’m using Windows XP 64 Bit may this can be the issue of the problem.
      Thanks for every kind of help
      luedt
      • moles42M Offline
        moles42 Alpha Testers
        maybe worthwhile you trying the latest release ?
        http://dl.powerarchiver.com/pacl601.exe
        Windows 10 Pro x64
        Intel Core i5 3470 @ 3.20GHz
        8.00GB Dual-Channel DDR3
