    B basitbulbulia
    Question Regarding License
    S Skybird
    PACL 9.0 Beta 2
    Michael72M Michael72
    BigMikeB BigMike
    Hi, there’s a problem with PAComp and file names with a leading ".\ ". That’s nowadays a problem, since PowerShell auto complete will complete a file test.zip in the current directory to .\test.zip. [image: 1524826662978-pacomp.png] The first command reports “All OK”, but test.7z is not created. The second command reports an error, but the error message isn’t helpful at all. VSS doesn’t help anything if a program fails to write to a file. It’s for reading locked files… And the problematic file isn’t mentioned at all. By the way, there’s a typo, it should be “open”, not “opet”. Only the third command (without ".\ ") works as expected. The problem exists in the x86 and x64 version, it doesn’t matter if the archive already exists (updating) or not (creating a new archive).
    czip support
    PACL 8.0 Beta 1
    P Prateek kumar
    PAConv.bat
    BigMikeB BigMike
    Profile Details
    B Brazilian
    Pacl 8.0
    How to encrypt file names?
    F farukhsharipov
    B BossHauss
    PACOMP -fips and -e2 commands
    F farukhsharipov
    F farukhsharipov
    F farukhsharipov
    Archive based on age
    O oblivion
    G GOZARCK
    Hi in pacomp.vbs by Micke how to preserve the folders structure of the files to compress.:confused: because just compress the files not the folder structure of each file. thanks '******************************************************************* '* PACOMP.vbs '* @author: Micke '* @hist 2010-02-26 CREATED:Script for compress multiple file types '* @hist 2010-03-01 BUGFIX: Space in path or filename resulted in '* no archive was created. '* '* Script for compress multiple file types '* '* Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath '* Example1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D: '* Example2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp '* '******************************************************************* Option Explicit 'Variables Dim FSO, objDir, aList, FileExtension, ArchiveName, DrivePath Dim aFile, aItem, strCompressionString, WshShell 'Constants (Change path to your own enviroment) Const PACOMP = "C:\Programs\PACL\PACOMP.exe" 'Check number of arguments If WScript.Arguments.Count <> 2 Then WScript.Echo "Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath" WScript.Echo "Example 1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:" WScript.Echo "Example 2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp" WScript.Quit End If 'Create the FileSystemObject Set FSO = CreateObject("Scripting.FileSystemObject") 'Create the ShellObject Set WshShell = CreateObject("WScript.Shell") 'Get data from the Arguments ArchiveName = WScript.Arguments.Item(0) DrivePath = WScript.Arguments.Item(1) 'Get the Folders for the DrivePath Set objDir = FSO.GetFolder(DrivePath) 'Create a Array with Fileextensions for the archive, change to your enviroment aList = Array("png", "jpg", "avi") 'Search through the folders SearchFolders(objDir) 'Sub for Searching recursive in Folders Sub SearchFolders(pstrCurrentPath) For Each aFile In pstrCurrentPath.Files For Each FileExtension In aList If FileExtension = LCase(Right(CStr(aFile.Name), 3)) Then AddFileToArchive aFile.Path End If Next Next For Each aItem In pstrCurrentPath.SubFolders SearchFolders(aItem) Next End Sub Sub AddFileToArchive(pstrFileName) 'Create the string with parameters for PACOMP strCompressionString = PACOMP & " -a -P " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34) WScript.Echo strCompressionString WshShell.Run strCompressionString, 0, True End Sub
    My password
    M mrabdoxxx
    Problem with NTFS compressed drives
    3 Posts 2 Posters 10.1k Views
    • C Offline
      CarlGray
      I have found a rather strange problem with PACOMP working on an NTFS drive that has compression turned on. It seems that any file that does not have the “archive” attribute set will not be added to the archive. I am using PACL 3.50 but have tested under 4.00 beta and it doesn’t work there either. I am NOT using the new “aa” option.
      If I disable compression even just for the folder I am trying to archive it will then work with any file regardless of the “archive” attribute.
      Is this a bug or is there something I need to do to get PACOMP to archive all files in the folder, regardless of the “archive” attribute?
        ivan conexware
        I will check the issue.
          ivan conexware @ivan
          The issue will be fixed in next release - 4.00 BETA 2.
