    B basitbulbulia
    Question Regarding License
    S Skybird
    PACL 9.0 Beta 2
    Michael72M Michael72
    BigMikeB BigMike
    Hi, there’s a problem with PAComp and file names with a leading ".\ ". That’s nowadays a problem, since PowerShell auto complete will complete a file test.zip in the current directory to .\test.zip. [image: 1524826662978-pacomp.png] The first command reports “All OK”, but test.7z is not created. The second command reports an error, but the error message isn’t helpful at all. VSS doesn’t help anything if a program fails to write to a file. It’s for reading locked files… And the problematic file isn’t mentioned at all. By the way, there’s a typo, it should be “open”, not “opet”. Only the third command (without ".\ ") works as expected. The problem exists in the x86 and x64 version, it doesn’t matter if the archive already exists (updating) or not (creating a new archive).
    czip support
    PACL 8.0 Beta 1
    P Prateek kumar
    PAConv.bat
    BigMikeB BigMike
    Profile Details
    B Brazilian
    Pacl 8.0
    How to encrypt file names?
    F farukhsharipov
    B BossHauss
    PACOMP -fips and -e2 commands
    F farukhsharipov
    F farukhsharipov
    F farukhsharipov
    Archive based on age
    O oblivion
    G GOZARCK
    Hi in pacomp.vbs by Micke how to preserve the folders structure of the files to compress.:confused: because just compress the files not the folder structure of each file. thanks '******************************************************************* '* PACOMP.vbs '* @author: Micke '* @hist 2010-02-26 CREATED:Script for compress multiple file types '* @hist 2010-03-01 BUGFIX: Space in path or filename resulted in '* no archive was created. '* '* Script for compress multiple file types '* '* Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath '* Example1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D: '* Example2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp '* '******************************************************************* Option Explicit 'Variables Dim FSO, objDir, aList, FileExtension, ArchiveName, DrivePath Dim aFile, aItem, strCompressionString, WshShell 'Constants (Change path to your own enviroment) Const PACOMP = "C:\Programs\PACL\PACOMP.exe" 'Check number of arguments If WScript.Arguments.Count <> 2 Then WScript.Echo "Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath" WScript.Echo "Example 1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:" WScript.Echo "Example 2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp" WScript.Quit End If 'Create the FileSystemObject Set FSO = CreateObject("Scripting.FileSystemObject") 'Create the ShellObject Set WshShell = CreateObject("WScript.Shell") 'Get data from the Arguments ArchiveName = WScript.Arguments.Item(0) DrivePath = WScript.Arguments.Item(1) 'Get the Folders for the DrivePath Set objDir = FSO.GetFolder(DrivePath) 'Create a Array with Fileextensions for the archive, change to your enviroment aList = Array("png", "jpg", "avi") 'Search through the folders SearchFolders(objDir) 'Sub for Searching recursive in Folders Sub SearchFolders(pstrCurrentPath) For Each aFile In pstrCurrentPath.Files For Each FileExtension In aList If FileExtension = LCase(Right(CStr(aFile.Name), 3)) Then AddFileToArchive aFile.Path End If Next Next For Each aItem In pstrCurrentPath.SubFolders SearchFolders(aItem) Next End Sub Sub AddFileToArchive(pstrFileName) 'Create the string with parameters for PACOMP strCompressionString = PACOMP & " -a -P " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34) WScript.Echo strCompressionString WshShell.Run strCompressionString, 0, True End Sub
    My password
    M mrabdoxxx
    "CRC Error" on PACL but not Power Archiver
    4 Posts 2 Posters 13.6k Views
    • C Offline
      chrisb
      I have some zip files which produce a “CRC Error” when extracted using PAEXT.
      The strange thing is that if I try and extract the same file using Power Archiver, there is no “CRC Error” and the extracted file is identical (same MD5SUM).
      Does anyone know what may be causing this? Is the zip file corrupt (in which case Power Archiver is failing to pick up on the corruption), or is the zip file fine (in which case PAEXT is incorrectly flagging an error)?
      Many thanks,
      Chris
        Maybe:-
        PAEXT : ZIP v4.5 format (extra large archives) is not supported.
        Whereas it is supported by PowerArchiver.
        • C Offline
          chrisb @TBGBe
          Is there a way that I can confirm whether Zip v4.5 format is causing the problem? The zip files are not particularly large (about 100Mb).
          What is strange is that the “CRC Error” only applies to about 5% of the files I try and extract this way - the rest are fine. And even if there is a “CRC Error”, the extracted file still seems to be identical to the file extracted by PowerArchiver. Is this likely to be caused by the v4.5 format?
          Thanks,
          Chris
            TBGBe @chrisb
            The 4.5 format allows “large archives”.
            This is used when :-
            A) Number of data files/folders >65500 (approx)
            B) Size of data files before compression >4GB
            C) Size of zip file after compression >4GB
            So if your zip file is only 100MB, I doubt B) or C) apply.
            Only you know if A) applies to these zip file(s) :D
            I can only guess at possible differences that are NOT really errors in PAEXT or PowerArchiver.
            If you know how to create one of these zip files or if you provide an example zip with the problem (e.g. url to access a “bad” zip file) then it could be checked by PACL/PowerArchiver devs. If not, all we can do is guess.
