    UI issues PA 20.00.53 / Classic Interface
    3 Posts 2 Posters 1.3k Views 2 Watching
    • BigMikeB Offline
      BigMike
      there are some issues with the UI in the classic interface:
      1. The “Print button” to create a file listing of the files in the archive opens an empty drop down menu.
        Clicking on the empty entry let me save the file listing as txt file, the entry for html files is missing completely.
      2. The toolbar for the file preview feature is cut at the window edge. Options on the right aren’t accessible at all.
      Kind regards
        Thanks @BigMike
        Logging in #1
        Spoke to the dev regarding #2 a while ago about the issue and it seems to be a bug in the component we use and nothing we can do on our end, unfortunately, until the component is updated with the fix.
        Thanks again!
        BigMikeB 1 Reply Last reply Reply Quote 0
        • BigMikeB Offline
          BigMike @Mili
          I confirm issue #1 doesn’t happen anymore in v20.10.02.
          Thanks for fixing :)
