    Fast Ring: PowerArchiver 2017 17.01.04
    7 Posts 2 Posters 12.6k Views 1 Watching
      Release Notes - PowerArchiver - Version 17.01.04
      ** Improvement
      * [PA-1096] - sorting by extension enable
      * [PA-1100] - Remove password policy requirements when creating a PGP archive
      * [PA-1132] - add .mzz to the same steps as MSI
      * [PA-1133] - add rll files to exe steps
      * [PA-1138] - Only one password input field when creating a PGP archive and decrypting a PGP archive
      * [PA-1160] - do not show update prompt if uses drag and drops files to archive
      * [PA-1173] - add pa format under All Archives drop down in Add Window
      * [PA-1174] - add new 1t solid switch for max, ultra and extreme modes
      * [PA-1176] - small changes for English translation
      * [PA-1177] - improve exe/dll compression with plzma:a0 setting for c_adr output
      * [PA-1180] - add 1p4 extension to exe/dll step
      ** Task
      * [PA-1120] - remove POWERARC-PACKMP3.EXE from installer (not used)
      * [PA-1127] - update Simplified Chinese translation (zh-CN)
      * [PA-1137] - change default update ring to slow ring (first installs, reset to default).
      * [PA-1169] - implement latest advanced codec pack engine
      * [PA-1175] - remove extra japanese shell translation
      ** Bug
      * [PA-742] - PAES Standalone: Open PGP Keys tool does not refresh when clicking back arrow
      * [PA-1098] - deleting PGP keys in PGP manager
      * [PA-1116] - Backup: Cloud account not showing in final screen
      * [PA-1123] - changing highlight archives color, config window loses focus, shows always white in config even if selected color works properly.
      * [PA-1128] - enterprise: disabled features still show under new> button
      * [PA-1136] - Small spelling fix in incorrect registration codes dialog
      * [PA-1156] - change configure clouds shortcut to o
      * [PA-1163] - zip crc error on 32bit OS
      * [PA-1168] - mp3 files not showing correct memory usage calculation
      * [PA-1170] - try to start backup, av shows.
      * [PA-1179] - Favorite Folders, Converter dialog is empty
      * [PA-1181] - AV error when extracting PA format via shell in Windows XP
      Added 04/10/2017
      * [PA-1189] - burner translation not showing properly
      * [PA-1190] - onedrive login issues as of 2/10/17
      PA 2017 17.01.04 download:
      http://dl.powerarchiver.com/2017/powarc170104.exe
      Please check it out and let us know if everything you use works correctly. Build is now live on patchbeam.
      Thanks! @Alpha-Testers
      • Brian GregoryB Offline
        Brian Gregory Alpha Testers
        Near the end of manually installing this over 17.00.92, it said it would restart the programs it has stopped to allow the upgrade. However, it did not seem to restart PASTARTER. The same happened on both my PCs. They run 64 bit Windows 7. I have PA’s Queue disabled.
          spwolf conexware @Brian Gregory
          @brian-gregory if it is PA Queue is disabled, then it should not start anyway. Thanks!
            @Alpha-Testers updated OP with list of issues fixed.
              Brian Gregory Alpha Testers @spwolf
              @spwolf But the option to have PASTARTER present even when queue is disabled exists in PA and I use it that way.
                @brian-gregory said in Fast Ring: PowerArchiver 2017 17.01.04 (unreleased):
                seems like Inno setup issue… we will check it out for 2018. Keep in mind that usually we use patchbeam these days so it wont do that.
                  @Alpha-Testers portable and business versions now live on download site. Fast ring on Patchbeam for today, moving to Slow ring tomorrow.
