    Problems with changing display options
    8 Posts 3 Posters 4.1k Views 2 Watching
    • BigMikeB Offline
      BigMike
      I’m using the new PowerArchiver 2017 release 17.00.90 on Windows 10 (x86) and have some problems, setting up the program window:
      • Unselecting the option “Show Button Text” in the toolbar is not persistent, if I close PowerArchiver and open it again, the Text will be shown again
      • Also, if I deselect “Show Button Text”, it’s still shown in the Backup view, if I tick or untick this option in the backup view, it has simply no effect in this view! I’ve already reported this here
      • I’ve dragged the “Preview Window” from the right side and dropped it on the bottom, so that it should be displayed on bottom of folder tree and files view. But it isn’t shown at all anymore, while the toolbar button shows, it’s still active. This is session persistent.
      • There seem to be no classic icons for “Encode” and “Repair ZIP”, but only Windows 10 style icons
        check out new .91 via Patchbeam, it should work properly now. Thanks!
        • C Offline
          ckit Alpha Testers
          1. Can’t Confirm
          2. Confirmed
          3. I think this is a known issue
          4. Confirmed
            spwolf conexware @BigMike
            thanks, wrote them in today…
              • BigMikeB Offline
                BigMike
                I can confirm, that 1,2 and 4 are fixed :)
                But I still can’t drag the preview windows to the bottom.
                  @bigmike we had to disable drag to the bottom, now we have regular windows there (ftp, cmd) due to problems we had with resizing with too many panels… hopefully in PA 2018 and new panels we will make it work again.
                  BigMikeB 1 Reply Last reply Reply Quote 1
                  • BigMikeB Offline
                    BigMike @spwolf
                    @spwolf So maybe it would be a good idea to disable the possibility to drag the preview to the bottom. As it is now, the preview pane simply disappears and I have to delete the registry key to reset the display options to get it back.
                      @bigmike sounds smart, i wrote it in…
