    Problem with archives created by Rainlendar
    4 Posts 3 Posters 3.2k Views 1 Watching
    • BigMikeB Offline
      BigMike
      Hi, Rainlendar creates backup ZIP archives from its important files.
      Opened in PowerArchiver only one file is shown, the archive information says, there’s only one file, but Windows Explorer shows all files and also when I test the archive in PowerArchiver, all files are shown in the report.
      By the way, it’s the same with PACL
      Please tell me, where I can provide a sample.
        downloading Rainlendar and will give it a try to reproduce.
        If can’t, will let you know to provide a sample archive.
        thanks for the info!!
          confirmed and logged in, thanks BigMike!
            Hello BigMike,
            We have released Fast Ring update that added support for this archive:
            http://forums.powerarchiver.com/topic/5511/fast-ring-pa-2016-16-10-23
            There was something wrong with the header, but we made workaround so it works properly now. Thanks for the report!
