    Outlook & PAOP add-in problem
    9 Posts 2 Posters 5.1k Views
    • K Offline
      Knightbeat40
      When I start Outlook up I get the below error message:
      Anyone know how to fix this?
      Thank you for your time.
      Kind Regards
      • K Offline
        Knightbeat40
        Not quite sure why image link did not work.
        This should work:
        https://www.dropbox.com/s/h5hmdsx3wpo7q43/Snap1.jpg?dl=0
          spwolf conexware @Knightbeat40
          @Knightbeat40:
          This should work:
          are you using latest PAOP? What version of Outlook? We currently dont have reported issues with PAOP… Thanks!
          • K Offline
            Knightbeat40 @spwolf
            Hi, Using Outlook 2010, yes latest PAOP.
              @Knightbeat40:
              did this happen first time you installed PAOP or after a while? Are there any other plugins installed before/after this started happening?
              • K Offline
                Yes after PAOP was installed. There are other plugins.
                  can you please send us a screenshot of list of your addins that are loaded by Outlook 2010, and we will check if we can reproduce with same ones… you can post it here or send it over to support at conexware dot com if you want to keep it private.
                  • K Offline
                    Here is the screenshot https://www.dropbox.com/s/d6fmuqqz58ohdri/Image%201.jpg?dl=0
                      @Knightbeat40:
                      Ah, so you cant run PAOP and ZTE together… they do the same thing. ZTE is for when you want independent compression for Outlook and shell, without PowerArchiver installed and PAOP is when you already have PA installed.
