    ImgBurn 2.5.8.0 ISO images and PowerArchiver Toolbox
    14 Posts 5 Posters 15.8k Views
    • C Offline
      ckit Alpha Testers
      Ok I have a small 1Mb ISO (4 XML logs for MBAM) compressed called “Test.7z” that also doesn’t display contents in PA which was created with ImgBurn 2.5.8.0.
      Please see what you can make of it?
      attachment_t_6181_0_test.7z
      • C Offline
        ckit Alpha Testers
        PowerArchiver doesn’t recognise ImgBurn’s ISO’s as valid archives!
        • C Offline
          ckit Alpha Testers @ckit
          Just re-created the same ISO with the same files as “ISO9660\Joliet” instead of “UDF” and PowerArchiver has no problem displaying the files at all!
          PowerArchiver has problems with UDF 2.01 ISO’s created by ImgBurn 2.5.8.0 it would seem.
          Update, no problems with UDF 1.02 ISO’s.
          Update, no problems with UDF 1.50 ISO’s.
          Update, problems with UDF 2.00, 2.50 and 2.60 ISO’s.
            thanks, we will check it out.
            • C Offline
              ckit Alpha Testers @spwolf
              I’m sorry to do this to you but this is still an issue with PA 2016 RC2 build 50.
              This ISO in screenshot opens fine in WinRAR 5.30 x64 but in PA there is nothing at all.
                gonna install imgburn and give it a try with the latest version. thanks!
                • C Offline
                  ckit Alpha Testers
                  ISO types:
                  ISO 9660 Juliet most works (just found one that doesn’t)
                  UDF 1.x works
                  UDF 2.x doesn’t work
                  I think it depends on the type of ISO and what app created it, IMGBurn in this case.
                    MDuss @ckit
                    I have here an similar Problem.
                    I get from an friend an iso Image with an photo Collage.
                    The file Extension ist .img
                    With Powerarchiver 2015 I have no Problem to open this file.
                    But with powerarchiver 2016 i have no possibility to open the file or extract the files within the iso imge.
                    I have no Infos about what for an configuration my friend has used to create the Image file.
                    But until know I had no reason to know the configuration because i had never an problem to open this iso files until now.
                    MfG
                    MDuss
                      Mili conexware @MDuss
                      @MDuss:
                      MfG
                      MDuss
                      would you or your friend be able to send us an .img/.iso file that does not work as described above?
                      Just tested creating and ISO and and IMG via IMGBurn, both opened fine in latest PA 16.03.01.
                      Can you send us some of the files you are using to create the IMG/ISO that does not work in PA?
                      We’ll try with those.
                      You can send to support at conexware dot com
                        MDuss @Mili
                        Hi Mili.
                        The files are very big, nearly 2.5GB, so it is not very easy to send them.
                        I send my friend in Australia an email so that he try it again with the iso file.
                        Maybe it will work than.
                        MfG
                        MDuss
                        D spwolfS 2 Replies Last reply Reply Quote 0
                          davidsplash @MDuss
                          one suggestion that could help is send them the file via dvd post wise.
                          second suggestion would be to look at the type of iso that has been created. Try a different setting to produce another iso that powerarchiver can read then we can highlight a seting or iso format that powerarvchiver needs updating/ adding.
                          What iso format is being created? that’s the question.
                            spwolf conexware @MDuss
                            @MDuss:
                            Hi Mili.
                            MfG
                            MDuss
                            ask him how is he creating them and if he can do a small one in the same way?
                              Yes, what spwolf mentioned and I’ll try creating multi-gig ISO today via ImgBurn using different options, lets see
                                MDuss @Mili
                                HI.
                                I will see that my friend make a complete new imagefile.
                                Hope that this will work.
                                MfG
                                MDus
