    FTP from shell = high CPU usage
    19 Posts 5 Posters 13.7k Views
    • I Offline
      iDunk
      I registered on the forum to report a couple of problems I’ve been having with Powerarchiver 2012 Professional.
      I am glad to see that the first problem has already been taken care of, namely, the hanging of PASTARTER.EXE introduced with 13.01.03 - fixed in 13.01.04.
      The second problem is high CPU usage when using “FTP It…” shell extension. I made a few PA backup scripts which make encrypted 7z archives, copy these archives to two other locations (nice feature), and then FTP these archives to a remote FTP server (another nice feature). All is well, with regard to CPU usage, when PABackup.exe is doing the FTP file transfer, but when I right-click a file and click an FTP profile the CPU usage of POWERARC.EXE doing the file transfer goes way up - maxing out a core if I set process affinity to just one core. I cannot tell you when this problem started since I have not been using this feature for long, and I only noticed this summer due to high revving CPU fan.
      Hopefuly this is something that can be fixed in a future release.
      Best regards,
      iDunk
        @iDunk:
        Best regards,
        iDunk
        thanks a lot, we will try to reproduce it and let you know if we have any questions.
        Does the actual FTP upload finish?
        • I Offline
          iDunk @spwolf
          Yes, the upload always finishes ok. Process Explorer shows a high cycles delta at offset 0x875470, if that is of any help.
          System info: Windows 7 Pro, Core i5 750, 8GB RAM, latest NIC driver
          Antivirus is Kaspersky Internet Security 2013 (happened also with 2012). I think I can exclude the antivirus/firewall as the culprit since all Conexware programs are in the trusted group and yet pabackup.exe and powerarc.exe behave differenty doing FTP.
            ok, sounds good… we will let you know when our testing goes though it… if we can reproduce it, it will probably be fixed in next release (few weeks).
              I was able to reproduce this and have logged it in.
              thanks for the detailed report!
              • P Offline
                phirephoto @Mili
                @Mili:
                I’m a new user of PowerArchiver and I’m experiencing this too however I’m not activating any extensions - I performed a clean install on two computers, and both frequently go to 50 - 51% CPU usage. Windows 8 on both machines.
                Any suggestions?
                Thanks.
                  spwolf conexware @phirephoto
                  @phirephoto:
                  Any suggestions?
                  Thanks.
                  disable pa starter from starting, it is issue that was solved in last release. Ctrl-alt-del and kill pastarter.exe process.
                  pastarter was not compatible with win8 so we had to rewrite it completely. You can disable its startup in Options> Configuration> PA Queue.
                  • P Offline
                    phirephoto @spwolf
                    Thanks, I’ll give that a shot!
                    • I Offline
                      iDunk @phirephoto
                      High CPU usage with FTPit still present in 13.03.01 and 13.03.02 :(
                        thank you, we got stuck on 2013 for a while, but now we are good to go.
                        • I Offline
                          iDunk @spwolf
                          The problem is still present in 14.0.17.0.
                          • I Offline
                            iDunk @iDunk
                            Any chance of fixing this in 2013 final?
                              aaaaaa!
                              will check it out this week, final or no final.
                              • I Offline
                                iDunk
                                Hi!
                                Sooo, is there a chance of this ever getting fixed? I just tried with 15.0.35 and the same problem is present, as always. FTP it… shell extension maxes out a core. Shame, such a nice little feature but not really usable for large files, mostly for power issues.
                                  I will check with team whats going on here.
                                    Socrates Banned
                                    I have ample CPU, so it does not create a problem for me.
                                    I can verify CPU usage spikes (goes from 1-2% to 25%).
                                    With FileZilla, it never moves my CPU about 2%.
                                    I think, though, that the problem is more general than FTP. Just compressing a folder from the shell jacks my CPU up to almost 25%.
                                    And . . . Compressing a folder from within the PA main window gets the CPU to 29%! Maybe it is the nature of multi-core compression. Not sure.
                                      there was a specific problem with ftp where cpu would spike with no reason.
                                      For ZIP compression, it is best to use all of the cpu :-)
                                      • I Offline
                                        iDunk
                                        Yes, compression will do that to a cpu ;) But we are talking about ftp file transfers here. Something which should not task a cpu so much.
                                          Tested with the newest RC 2015 and putting on the list for the dev team to check out for the next update.
                                          Thanks for bringing it up :)
