    B basitbulbulia
    Question Regarding License
    S Skybird
    PACL 9.0 Beta 2
    Michael72M Michael72
    BigMikeB BigMike
    Hi, there’s a problem with PAComp and file names with a leading ".\ ". That’s nowadays a problem, since PowerShell auto complete will complete a file test.zip in the current directory to .\test.zip. [image: 1524826662978-pacomp.png] The first command reports “All OK”, but test.7z is not created. The second command reports an error, but the error message isn’t helpful at all. VSS doesn’t help anything if a program fails to write to a file. It’s for reading locked files… And the problematic file isn’t mentioned at all. By the way, there’s a typo, it should be “open”, not “opet”. Only the third command (without ".\ ") works as expected. The problem exists in the x86 and x64 version, it doesn’t matter if the archive already exists (updating) or not (creating a new archive).
    czip support
    PACL 8.0 Beta 1
    P Prateek kumar
    PAConv.bat
    BigMikeB BigMike
    Profile Details
    B Brazilian
    Pacl 8.0
    How to encrypt file names?
    F farukhsharipov
    B BossHauss
    PACOMP -fips and -e2 commands
    F farukhsharipov
    F farukhsharipov
    F farukhsharipov
    Archive based on age
    O oblivion
    G GOZARCK
    Hi in pacomp.vbs by Micke how to preserve the folders structure of the files to compress.:confused: because just compress the files not the folder structure of each file. thanks '******************************************************************* '* PACOMP.vbs '* @author: Micke '* @hist 2010-02-26 CREATED:Script for compress multiple file types '* @hist 2010-03-01 BUGFIX: Space in path or filename resulted in '* no archive was created. '* '* Script for compress multiple file types '* '* Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath '* Example1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D: '* Example2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp '* '******************************************************************* Option Explicit 'Variables Dim FSO, objDir, aList, FileExtension, ArchiveName, DrivePath Dim aFile, aItem, strCompressionString, WshShell 'Constants (Change path to your own enviroment) Const PACOMP = "C:\Programs\PACL\PACOMP.exe" 'Check number of arguments If WScript.Arguments.Count <> 2 Then WScript.Echo "Usage: cscript PACOMP.vbs ArchiveName.extension DrivePath" WScript.Echo "Example 1: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:" WScript.Echo "Example 2: cscript PACOMP.vbs C:\Temp\MyArchive.zip D:\Temp" WScript.Quit End If 'Create the FileSystemObject Set FSO = CreateObject("Scripting.FileSystemObject") 'Create the ShellObject Set WshShell = CreateObject("WScript.Shell") 'Get data from the Arguments ArchiveName = WScript.Arguments.Item(0) DrivePath = WScript.Arguments.Item(1) 'Get the Folders for the DrivePath Set objDir = FSO.GetFolder(DrivePath) 'Create a Array with Fileextensions for the archive, change to your enviroment aList = Array("png", "jpg", "avi") 'Search through the folders SearchFolders(objDir) 'Sub for Searching recursive in Folders Sub SearchFolders(pstrCurrentPath) For Each aFile In pstrCurrentPath.Files For Each FileExtension In aList If FileExtension = LCase(Right(CStr(aFile.Name), 3)) Then AddFileToArchive aFile.Path End If Next Next For Each aItem In pstrCurrentPath.SubFolders SearchFolders(aItem) Next End Sub Sub AddFileToArchive(pstrFileName) 'Create the string with parameters for PACOMP strCompressionString = PACOMP & " -a -P " & Chr(34) & ArchiveName & Chr(34) & " " & Chr(34) & pstrFileName & Chr(34) WScript.Echo strCompressionString WshShell.Run strCompressionString, 0, True End Sub
    My password
    M mrabdoxxx
    PACL 7.00 b1 file extension upper case problem
    6 Posts 3 Posters 12.5k Views
    • MickeM Offline
      Micke Alpha Testers
      Hi!
      I have found out something interesting in the PACL 7.00 b1 version. I haven’t tested this in PACL 6.01 yet, so I can’t tell if this only happends in PACL 7.00 b1.
      Anyway, here’s a list of files I’ve been using for tests.
      2012-02-05  16:07    <kat>          .
      2012-02-05  16:07    <kat>          ..
      2010-02-24  18:28         1***censored***077***censored***633 Amiga XP x86.pdf
      2009-12-15  22:31            73***censored***328 Deluxe Paint 4 Manual.pdf
      2012-02-05  15:12                 4 password.txt
      1997-09-08  22:52            73***censored***648 REFSCAN1.PCX
      1997-09-08  22:55            57***censored***080 REFSCAN2.PCX
      1997-09-08  22:56            36***censored***833 REFSCAN3.PCX
      1997-09-08  22:58            57***censored***612 REFSCAN4.PCX
      1997-09-08  23:00            55***censored***959 REFSCAN5.PCX
      1997-09-08  23:02            31***censored***751 REFSCAN6.PCX
      2012-02-05  15:30            54***censored***230 Test1.zip
      2012-02-05  16:12    <kat>TF
                    10 fil(er)           1***censored***518***censored***078 byte
                     3 katalog(er)  17***censored***113***censored***018***censored***368 byte ledigt
      C:\PACL_Test\Amiga></kat> </kat></kat>
      ```Pay attention to the file names REFSCAN that have the file extension in upper case (.PCX).
      I the try to create a zip archive with all the PCX files in it.
      C:\PACL_Test\Amiga>pacomp -a Test2.zip REFSCAN*.PCX
      PowerArchiver Command Line (PACL) Version 7.00 [Jan 29 2012]
      Copyright© 1998-2012 ConeXware, Inc. All Rights Reserved. Shareware Version
      Remainder: This is unregistered version of PACL. Please register at http://www.p
      owerarchiver.com
      Press <enter>to continue.
      Archive Compression Utility – ZIP,ZIPX,7-ZIP,CAB,LHA,BH,JAR,TAR,GZIP,BZIP2
      Internet: http://www.powerarchiver.com Email: support@conexware.com
      Archive: C:\PACL_Test\Amiga\Test2.zip
      preparing to compress…
      *** WARNING: Nothing to add or update…
      All OK
      C:\PACL_Test\Amiga></enter>
      C:\PACL_Test\Amiga>pacomp -a Test2.zip REFSCAN*.*
      owerarchiver.com
      All OK
      C:\PACL_Test\Amiga>pacomp -a Test2.zip REFSCAN*.pcx
      owerarchiver.com
      All OK
      I then change to another folder that also had some .pcx files in it.
      2012-02-05 15:39 <kat> .
      2012-02-05 15:39 <kat>…
      2009-09-14 22:32 27censored760 3Pluto.pcx
      2009-09-14 22:32 42censored917 4Goofy.pcx
      2009-09-14 22:32 28censored119 5Donald.pcx
      2009-09-14 22:32 28censored919 6Daisy.pcx
      2012-02-05 15:39 103censored786 Test2.zip
      5 fil(er) 231censored501 byte
      2 katalog(er) 17censored113censored022censored464 byte ledigt
      C:\PACL_Test\Amiga\TF></kat> </kat>
      C:\PACL_Test\Amiga\TF>pacomp -a Test3.zip *.pcx
      owerarchiver.com
      Archive: C:\PACL_Test\Amiga\TF\Test3.zip
      adding: 3Pluto.pcx --> Done. [21%]
      adding: 4Goofy.pcx --> Done. [55%]
      adding: 5Donald.pcx --> Done. [77%]
      adding: 6Daisy.pcx --> Done. [100%]
      All OK
      C:\PACL_Test\Amiga\TF></enter>
      C:\PACL_Test\Amiga\TF>pacomp -a Test3.zip *.PCX
      owerarchiver.com
      All OK
      Now It seems logic that the program treats .pcx and .PCX as different file extensions, but if the file extension for some reason is stored in upper case, why can't the program add them to the archive?
      Kind Regards
      Micke
        thanks a lot - we will check it out… 7.0 is big rework of all engines so i expect more buggies like this to happen.
        MickeM 1 Reply Last reply Reply Quote 0
        • MickeM Offline
          Micke Alpha Testers @spwolf
          Hi!
          I have now repeated the test using PACL 6.01. First look in the folder.
          2010-09-06  07:09
          <dir>          .
          2010-09-06  07:09
          <dir>          ..
          2010-07-28  20:32
          <dir>          TF
                         8 File(s)      1***censored***463***censored***844 bytes
                         3 Dir(s)  145***censored***127***censored***018***censored***496 bytes free
          I then try to create a zip archive using PACOMP and filenames REFSCAN*.*
          C:\Programs\Test\Amiga>pacomp -a Test1.zip REFSCAN*.*
          PowerArchiver Command Line (PACL) Version 6.01 [Feb 07 2010]
          Copyright© 1999-2010 ConeXware, Inc. All Rights Reserved. Registered Version
          This product is licensed to: Micke
          Archive: C:\Programs\Test\Amiga\Test1.zip
          adding: REFSCAN1.PCX --> Done. [23%]
          adding: REFSCAN2.PCX --> Done. [41%]
          adding: REFSCAN3.PCX --> Done. [53%]
          adding: REFSCAN4.PCX --> Done. [71%]
          adding: REFSCAN5.PCX --> Done. [89%]
          adding: REFSCAN6.PCX --> Done. [100%]
          All OK
          C:\Programs\Test\Amiga>pacomp -a Test2.zip REFSCAN*.PCX
          Archive: C:\Programs\Test\Amiga\Test2.zip
          All OK
          Kind Regards
          Micke</dir>
          </dir>
          </dir>
            Thanks Micke, logged in!
              PACL 7.00 RC1 http://www.powerarchiver.com/test/alpha120/pacl700.exe
              please check it out.
              • MickeM Offline
                Micke Alpha Testers
                Tested in PACL 7.00 RC1. Files will be added correctly independent of upper or lower case of file extension.
                Bug Fixed Confirmed
                Kind Regards
                Micke
