    Very high CPU usage while using 7zip compression
    10 Posts 3 Posters 22.2k Views
    • K Offline
      klumy
      I have a very high CPU usage while using 7zip compression at ultra high compression rate.
      at this time I nearly can’t do anything except letting PA compress the file
        deipotent
        Maybe if the user could choose to set the priority of PA, like audio players often allow. eg. Low, Medium, High.
        • K Offline
          klumy @deipotent
          yeah this would be great.
            spwolf conexware @klumy
            If you minimize PA to tray, it will set itself to lowest priority automatically… :-).
            Although the problem I find myself is that 7zip is in general very demanding on memory, cpu and hard drive so I am not sure if lowering priority helps. Compressing is very intensive task…
              deipotent @spwolf
              … so I am not sure if lowering priority helps. Compressing is very intensive task…
              It definitely would help. Lowering the priority would mean that other applications with higher priority would become more responsive during compression, at the expense of the compression taking a bit longer.
              • K Offline
                klumy @deipotent
                as I stated before, if you use compression ratio “NORMAL”, everything works fluently. Just if you select “ultra high” when compressing 7ZIP files the CPU Usage is very high.
                It would be great, if the CPU usage would be the same like it is in “NORMAL” compression
                BTW
                I don’t min if the compression takes longer. Normally you do all compression works in background, so you can work in another program.
                  @klumy:
                  BTW
                  There is nothing we can do about that - however if you minimize PA to the tray, it will set its cpu priority to lowest level, and your system should work faster.
                  Did you try it? Does it work better?
                  • K Offline
                    klumy @spwolf
                    yes, it does
                      @klumy:
                      yes, it does
                      good?!
                      • K Offline
                        klumy @spwolf
                        I think I can live with that
                        thanks ;)
