    CRC error w/split zip in PA 11.50.61
    35 Posts 3 Posters 29.8k Views
      spwolf conexware @dragon57
      @dragon57:
      I have more info, but no specifics that I feel confident will help.
      I have tried zipping and splitting large sets of files, but none cause the problem except those from my VMware sets of files, and not all of those.
      The problem appears to be related to zipping up large files that when finished, end up being near the end of the split boundary.
      Example, I had eleven vm files that were all nearly 2GB in size. If I zipped them in dictionary name order, I could repeat the error, but if I renamed them and zipped in a different order, the problem did not exist. File name length seems to have nothing to do with the error.
      Does any of this make any sense?
      not really, but i will try creating VM files of same size and reproducing it like that :)
        ivan conexware
        Sorry, I didn’t found an answer to one my question - does creating same ZIP archive with same files and size without spanning works fine?
          dragon57
          Yes, creating a zip with the same files without spanning works fine.
            dragon57
            Just fyi, the latest rc still has this same problem. ;)
              would it be possible for us to download those original files? Only way we can reproduce it (and fix it).
              Maybe try with less files but same folder (smaller file size) and see if that works or not, if we can get smaller sample it will be easier.
                dragon57
                The file set is over 32GB, plus this is a VMware image that contains proprietary software. There is no way I could get it to you. I’ll try to come up with a repeatable scenario that causes the problem using smaller and different files, however the problem only seems to show up at the DVD sized split boundary.
                  dragon57
                  See if you can reproduce the problem using the below steps.
                  Download http://www.bertel.de/software/rdfc/rdfc.zip
                  Unzip the rdfc.exe file and put it in a temporary directory with at least 37GB of space.
                  From the temporary directory, create the test files by running the following commands in order:
                  rdfc “Windows Server 2003 Standard Edition.vmdk” 1818
                  rdfc “Windows Server 2003 Standard Edition-s001.vmdk” 2146304000
                  rdfc “Windows Server 2003 Standard Edition-s002.vmdk” 2145976320
                  rdfc “Windows Server 2003 Standard Edition-s003.vmdk” 2139947008
                  rdfc “Windows Server 2003 Standard Edition-s004.vmdk” 2141257728
                  rdfc “Windows Server 2003 Standard Edition-s005.vmdk” 2145583104
                  rdfc “Windows Server 2003 Standard Edition-s006.vmdk” 2138832896
                  rdfc “Windows Server 2003 Standard Edition-s007.vmdk” 2140471296
                  rdfc “Windows Server 2003 Standard Edition-s008.vmdk” 2137587712
                  rdfc “Windows Server 2003 Standard Edition-s009.vmdk” 2135818240
                  rdfc “Windows Server 2003 Standard Edition-s010.vmdk” 2144796672
                  rdfc “Windows Server 2003 Standard Edition-s011.vmdk” 2146172928
                  Highlight all the vmdk files, right-click and select parameters per the attached pic.
                  I then open the .zip file in Winzip and perform a ‘Test’. I get a CRC error. If you unzip with PA, you should eventually get either a CRC error, an erroneous password prompt, etc.
                  Let me know if you have any questions.
                    extremly helpful, thanks a lot!
                      this issue has been fixed in next release :-)
                        and thanks a lot… huge help!
                          dragon57
                          That is so great. That had to be a hard one to diagnose and fix I bet. Great job and many thanks!
                            @dragon57:
                            going through 5 GB archives with hex editor = awesome :-)
                              You can re-download 11.60.12 from our website. Please check it out and see if this solved your issue.
                              We did not have a lot of time to test it out.
                                dragon57
                                Things are looking good. I tested two large directories that had problems before when zipped/split, but have no problems when zipped/split with the latest PA build. I’ll continue to keep a close watch on new zips going forward and let you know if I see a repeat of the problem.
                                  awesome. I will keep this thread open just in case :).
