    Intermittent hangs on 7zip extraction
    11 Posts 4 Posters 13.7k Views
    • B Offline
      By-Tor
      I’ve been experiencing intermittent hangs while extracting some 7zip files with PA 11.50.49. This past time, it happened while trying to extract a single file from an archive. It was 100% complete, but, the dialog box just sat, the buttons were clickable, but, didn’t exit the dialog. It had to be killed with task manager.
        how were you extracting it, shell?
        Do you have AV installed?
        • moles42M Offline
          moles42 Alpha Testers
          I can confirm this…
          I was extracting a 14 meg file from a 140 meg archive from within PA not via the shell and I cancelled it after 5 minutes of waiting.
          if I drag it from the archive to desktop it works fine but if I right click on the file and tell it to extract then this is where the problems begin.
          it extracted the file in question but the extracting info box as seen in By-Tor’s screenshot remains open indefinately.
          Windows 10 Pro x64
          Intel Core i5 3470 @ 3.20GHz
          8.00GB Dual-Channel DDR3
            spwolf conexware @moles42
            @moles42:
            I can confirm this…
            thats awesome, so how exactly are you doing it? right click on file in archive, then use extract button?
            by-tor - how did you extract yours?
            moles42M 1 Reply Last reply Reply Quote 0
            • moles42M Offline
              moles42 Alpha Testers @spwolf
              as shown in this screenie…that’s the method I use to reproduce this error.
              Windows 10 Pro x64
                very simple, single file extract dont seem to work… very happy about this :). People will think i am crazy but it is very important that bugs are found as we know that they are there we just need help locating them!
                • B Offline
                  By-Tor @spwolf
                  Ok, I’m glad that’s cleared up. I had extracted it using the full gui, highlighting the file, then choosing extract from the toolbar.
                  • A Offline
                    ACE135 @By-Tor
                    Just experienced the same problem.
                    Using same extraction method as By-Tor.
                      This issue has been fixed in following pre-release:
                      http://www.powerarchiver.com/test/alpha115/powarc1150rc3.exe
                      Please let me know if it works fine now. Thanks!
                      • A Offline
                        ACE135 @spwolf
                        Works fine now. Thanks.
                        • moles42M Offline
                          working fine for me now…:)
                          Windows 10 Pro x64
