    Problems with tar.gz files in 11.50.23
    11 Posts 4 Posters 7.5k Views
      demm
      since I upgraded to 11.50.23, PA has problems opening tar.gz files.
      On my Vista x64 quad-core machine, it shows me a CRC error.
      On my XP x86 single-core machine it just hangs up without an error.
      The error seems to occur turing the .tar phase, so extracting the .gz first seems to work.
      This happens with every tar.gz file I’ve tried so far, but opening .zip or .rar still works.
      Best regards.
      PS: I really love the changes you’ve made in the newest version. Thanks for such an awesome product.
      • moles42M Offline
        moles42 Alpha Testers
        can confirm a problem when opening a tar file…
        program just hangs and I have to close it via task manager.
        Windows 10 Pro x64
        Intel Core i5 3470 @ 3.20GHz
        8.00GB Dual-Channel DDR3
          thanks a lot!
          • T Offline
            Tonda @spwolf
            I receive this CRC error too.
            Easily reproducable because it happens with every .tar.gz file.
            German WinXP x86 SP3 DualCore
            German Powerarchiver 11.50.23
              yes, should be fixed in next release! thanks
              • moles42M Offline
                seems to be working fine for me now in 11.50.28
                but I have a question regarding the use of .tar and the ‘store’ method.
                I tested this option but it didn’t create any file for me even after several attempts.
                Windows 10 Pro x64
                  yes, we know :-)… thats why .28 was not official.
                    .30 is up and should be good with tar files…
                      Please check your issue with latest 11.50.30 release:
                      http://dl.powerarchiver.com/2010/powarc1150b1.exe
                      and let us know if this works better now.
                      • moles42M Offline
                        working fine for me in 11.50.30
                        many thanks.
                        Windows 10 Pro x64
                          not only that but both compression and decompression of tar.gz/bz2 should be a lot faster now :-)
