    Configuration - Speed options
    10 Posts 2 Posters 6.9k Views
    • drteethD Offline
      drteeth
      It is not clear at all from the help file if the ‘Use current folder as temp’ is meant to speed things up or not.
      Can anybody enlighten me?
      Cheers
      DrT
        yes, they are all there to speed up things
          basically, no moving of files accross hard drive… if you are compressing something on D: and your temp is on C: you will have to wait for compressed file to be moved from C: to D:, which can take long time…
          • drteethD Offline
            drteeth
            Okay, will tick the box.
            • drteethD Offline
              drteeth @drteeth
              @drteeth:
              Did as above, and PA is still using the default temp folder. The setting does not work, leastways on Vista SP1.
              I have three h/ds on my system and PA was not even using the same disk for its temp files, let alone the same folder :confused:.
              Regards
              DrT
                spwolf conexware @drteeth
                @drteeth:
                Regards
                DrT
                what format are we talking about?
                • drteethD Offline
                  drteeth @spwolf
                  I was unRARing a multipart RAR file that contained one file, if you get what I mean. I was working on my G: drive and the normal temp folder on C: was being used, monitored and confirmed using an open explorer window.
                  Also, still had the separate copy operation at the end of the unRAR.
                  Cheers
                  DrT
                    @drteeth:
                    Cheers
                    DrT
                    not sure if it is supported for rar format, we will check for beta 2
                    • drteethD Offline
                      drteeth @spwolf
                      For what file formats is this option supported? If it could be enabled for RAR it would be very handy indeed as I deal with them a lot.
                      Cheers
                      DrT
                        @drteeth:
                        Cheers
                        DrT
                        it is supported for all formats (or it should be) except for rar - unfortunatly unrar.dll does not have this option, nor it has option for keeping broken files (another wish that people wanted for long time).
