    Trayicon remains after extraction
    14 Posts 4 Posters 13.1k Views
    • K Offline
      klumy
      The PA Trayicon is still there even if the extraction of an archive is complete. You have to click on the PA trayicon, so it will disappear
        What exactly are you extracting? Or does it not matter?
        More info please…
          ivan conexware @spwolf
          PA icon in the tray could only left if you clicked on “Tray” while extracting and the extraction finished - but in this case a ballon showed up saying “Extraction of … finished. Click here…” and it would stay until you click on ballon or the PA icon itself.
          • K Offline
            klumy @ivan
            is it possible that the ballon showed up for a few seconds and then the trayicon will vanish
              ivan conexware @klumy
              PowerArchiver tray icon + ballon should disappear after some time - please wait for about 15 seconds and you should see.
              • K Offline
                klumy @ivan
                I waited 15 seconds.
                The ballon dissappear but the trayicon remains in tray
                ivanI spwolfS 2 Replies Last reply Reply Quote 0
                  Hm, is this happening from main PA window or when using explorer shell extensions?
                  • K Offline
                    klumy @ivan
                    it happens on both
                      spwolf conexware @klumy
                      I cant reproduce it on my computer, however it takes around 30-40 secs of baloon&icon to dissapear (not only on PA - Windows baloons as well).
                        TBGBe @spwolf
                        I can reproduce it on Win2k - I thought it was a feature !
                        Extract via shell and click on tray button.
                        On finishing the ballon shows, do nothing and the ballon disappears.
                        Still do nothing and tray icon stays - letting me know that extraction completed.
                        So, to me, I can go for a coffe and on return I can hover over icon and see which file I was working on :D
                        Note 1: Just tried on win98 and didn’t get the balloon - but the tray icon remained until clicked. Just testing but waited over three minutes after unzipping completed (although hover tooltip stopped at 99% complete)
                        Note 2: In both cases I have taskbar on “Auto-Hide” - is that relevant?
                          TBGBe @TBGBe
                          Icon still there on Win98 - now 20 minutes (I like this) :D
                            spwolf conexware @TBGBe
                            Might be connected with Auto Hide, will check this - I am not sure if this is an Windows feature that PA follows or do we actually make the icon dissapear after a while…
                            • K Offline
                              klumy @spwolf
                              bug is still there in PA 9.1 Final
                                @klumy:
                                Behaviour differes in different versions of Windows. I am not sure if we have ability to control it. We will check it a bit more for 9.2.
