    P
    Will you be releasing 2024 soon?
    Problem in french translation
    6870
    • P
      pascal
      Hello, there is a problem in the translation of French Pa on the level of Shell extensions; for certain functions the words to extract and compress are reversed.
        can you please specify the issues you see and we will fix it… thanks
        • P
          pascal
          afflicted but I have one can of evil with English, I use a translator for poster. The translation of French Shell is not good, of the inversions in the orders and the words.
          • TBGBeT
            TBGBe @pascal
            Maybe you could just post screen shots - showing the errors?
              he sent us the shots, and we sent it to translator…
                can you check this thread for solution:
                http://www.powerarchiver.com/forums/showthread.php?t=2465
                I believe simply copying of specific translation file from 10.01 will make it all work great…
                Please let us know.
                thank you!
                • P
                  pascal @spwolf
                  thank you for this bond, my problem is same, the Shell extension functions very well with version 10.01 but not with version 10.10. The encountered problems are the same ones.
                    even if you copy translation files and restart your computer?
                    • P
                      pascal @spwolf
                      with file PASHELL_FR.PLF of version 10.01 it’s ok
                      thank you very much
                        great, it will be fixed in 10.11… thank you!
