    Problem: download PA 9.64.2.0
    10
    6081
    • B
      blair
      For the first time ever I am having a problem downloading the latest update. I currently have v9.63.02. I have tried a number of times from the website and also from within PowerArchiver with and without the firewall on. It seems to download but when I try to install I always get a message that “The setup files are corrupt…”
      What should I do?
      Thanks,
      blair
      • D
        davidsplash
        no problemns this end what program your using to download pa with
        ever had zonealarm or cyberhawk running if so this might be the fault
        • RJWaringR
          RJWaring @davidsplash
          Blair,
          If you ever have problems downloading files and they are coming across as currupt this usually results in;
          Firewall
          Antivirus
          Spyware Checkers
          ISP Downtime
          Server Problems
          Wireless Downtime during download.
          Site server glitch.
          The best way to overcome these areas is by downloading a Download Manager such as;
          DAP “Download Manager”
          LeechGet 2006 etc
          This should help and both are available free
            @blair:
            What should I do?
            Thanks,
            blair
            hi,
            seems as if bad download got cached at your ISP. Best bet is to use some kind of download manager to download and it will work great.
            • RJWaringR
              RJWaring @spwolf
              isn’t that what I just said? but minus the techno bavel :D
                mwb1100 @RJWaring
                Also you might try clearing the browser’s cache (the “Tools/Internet Options…/Delete Files…” button in IE 6).
                • B
                  blair
                  Thanks for the help!!!
                  I download things successfully all the time without difficulty through MSN so I am not sure what is happening here.
                  I do not have Zone Alarm on my system. I use MSN 9 but the biggest change of late has been upgrading to IE 7. I have also recently bought into “Windows Live One Care” for Firewall, Antivirus, Spyware Checking etc.
                  IT FINALLY DOWNLOADED
                  I had been trying to download through MSN many many times but it never got up to 1M. I decided to try through IE7 and it worked (without turning off firewall etc.) but not the first time. It finally downloaded after the third attempts and 2 false readings of ± 2M then almost 3M.
                  Thanks for the mention of the download managers. I will hold those site locations on standby. It seems unfortunate to have to have a third party software to do such work. Others must not have the same problem, not sure why I did for it never happened before. If anyone else does have the problem may the info here will help.
                  Thanks again!!!
                  • Brian GregoryB
                    Brian Gregory Alpha Testers @RJWaring
                    @Sir:
                    LeechGet 2006 etc
                    I’ve found DAP has aquired very annoying bugs since about V7.5 and I’ll be abandoning it forever as soon as I find something else which suits me.
                      Get right, of course :-)
                      • guidoG
                        guido @spwolf
                        I use flashget. Also very good.
                        Guido
                        Windows 11 Pro ENU x64
                        Intel Core I7
                        32 GB RAM
