    P
    Will you be releasing 2024 soon?
    HELP WITH .pak files
    9
    23866
    • D
      DaGooN
      well its like this.
      PA8 was good for Extracting & making .pak files…
      since i got PA9… it wont let me do it no more.
      i put in the .pak at the end of the file & then try to do it as i normaly do.
      & it just dont work. it just does nothing…?
      Any Help would be nice :D
        Can you please outline what exactly are you doing, step by step…
        • ivanI
          ivan conexware @spwolf
          PAK files were never supported - even extracting was never supported. Can you please explain what you were doing in older versions and with which files?
          • D
            davidsplash @ivan
            This May Sound Starange But Some People Were Using Zip As Pak Files With Just The Extension Changed To Pak. Sounds Daft But Its True. I Found This Out Over The Internet As I Downloded A Pak Foile Only To Find It Was A Zip File In Discuise
            • ivanI
              ivan conexware @davidsplash
              I just tried renaming one ZIP file to PAK and then opening it from main PA interface - it worked fine and I could do anything as with ZIP files. Even creating PAK (as ZIP format) files went fine from main PA interface.
              From shell extensions it is not supported because shell-extensions are detecting file format based on its extension - so PAK files are not natually supported because they are not originally ZIP files! You should rename them to ZIP if you want to use them from shell extensions.
              This is not a BUG because there are REAL PAK files - this is very old format by NoGate Consulting - and they are not supported, and because of this PA is not displaying “Extract” items in shell-extensions for those files.
              It is true that PAK format is very similar to old v0.9 ZIP format - it uses same compression methods as old v0.9 ZIP format, but this format is not used any more and there is no reason for supporting it.
              • D
                DaGooN @ivan
                well ok…
                i have the Game FarCry…
                & it uses .PAK file Extensions
                in powerArchive 8… i was Abble to open them & then Extract the files… mod them in psp8
                then zip them up like this…
                DE_Camo.pak
                & it made the pak file… & worked fine…
                since i got powerArchive 901… i do the same thing… & it does nothing. it just dont work at all?
                so i uninstalled PA9 then Reinstalled PA8… & it worked fine again…?
                is there something in PA9 that maybe Causing this….
                p/s heres files i made with PA8… on my Download Section
                http://www.wereallrobots.tk/
                • J
                  jpnv8 @DaGooN
                  i like to extract the *.bik files inside the *.pak files i downloaded the dragon unpacker but it is not working i remembered that i downloaded the same program ( i think the the previous version) and it worked just fine >,< now it takes too long to browse through the *.pak files and extract it… i waana see the *.bik files … and play the ffviii scene >,< help me plese!! du u know any program to open the *.pak files… >,< i cant find any info in the web. >,< i found dragon unpacker (http://www.listsoft.com/17315) or maybe give link to older drangon unpacker >,< help me please pipol… >,<
                  • TBGBeT
                    TBGBe @jpnv8
                    @jpnv8:
                    i like to extract the *.bik files inside the *.pak files … and play the ffviii scene …
                    I don’t know what these “bik” files are, but why not do the reverse of what ivan suggested?
                    Copy/rename the .pak file to .zip
                    Then (if it really is an old Zip format) you can open it with PA and use Find to extract all the .bik files.
                    • B
                      Bighead
                      @DaGooN:
                      well its like this.
                      Although it should be handy to count on that feature in PA 9.x -'cause some games still use it to pack media files even though it’s an old format, you can still use ‘PAKScape’ to Extract & Make “real” .pak files.
                      Here’s a set of links to download pages: click here
                      I hope this helps.
