Navigation
    • pacl900b-190606.exe (PACL 9.0 Beta 5) pacomp -r not working.
      Brian Gregory
      I’m trying to backup the complete contents of a directory using:
      pacomp64 -parcz T:\BACKUP.PA C:\STUFF
      The contents of subdirectories of C:\STUFF isn’t getting backed up!
      The sub directories are just stored as empty directories!
    • When extracting 7z files extract only newer files
      B
    • Question Regarding License
      S
      Hello @Mili,
      thanks for your help in getting my PowerArchiver CommandLine license (Re: License Code Not Working / Missing) and sorry for my late reply. I do check my spam folder regularly and couldn’t find a mail from support. Also, there was no mail in my backups or any mention of it in my email logs.
      I have a question regarding my licenses in the hope you are able to help me:
      While my account lists “PowerArchiver Select - lifetime free upgrades and support for PowerArchiver Toolbox English - Count 2”, this does not apply for PACL, which was included with my purchase. My account shows only PowerArchiver Select - 12 months of upgrades and support for PowerArchiver Command Line - Single User License.
      Since PACL was included with PowerArchiver Toolbox, shouldn’t PACL also come with a lifetime license for 2 PCs?
      Thanks for your help in advance.
    • PACL 9.0 Beta 2
      spwolf
      Version:
      PACL 9.00 Beta 2
      What’s New since version PACL 7:
      Updated to PowerArchiver 2017 engine Fully unicode interface RAR v5 (v4) support PAE2 support
      Latest format support and all the various engine updates done in PA 2017.
      Full support for .PA format with many different options and switches.
      http://dl.powerarchiver.com/2017/PACL900-170429.EXE
      Due to the support of new PA format and all the changes needed for that support, we decided to move up version number to PACL 9. This is purely cosmetical - companies who purchased PACL8, have PACL9 now added to their orders. Users who have free upgrades for PACL8, now have PACL9 added as free upgrade (Business users with active select (pro/tbx), all personal users (pro/tbx).
      Since we are finalizing PA 2017, we can also now spend a lot more time on PACL9.
      Please check your bugs, and check .PA support as well.
      Thank you! @Alpha-Testers
      PA Team
    • The PACL does not extract files from the self-extracting archive
      Michael72
      My OS: Windows XP Home Edition, SP3
      The version number and date of the program: PowerArchiver Command Line v9.00b [Feb 23 2019]
      The program not extracts one self-extracting file.
      How to reproduce the problem
      Download the SFX file by link: install.exe
      Copy the “install.exe” file into the same location as the program is located.
      Go to the DOS prompt. Make your PACL location the default drive.
      If it is on the E drive enter the command E: and press enter. Replace “E:” with the appropriate drive letter.
      Enter command cd e:<path name> to go to the location where the program resides.
      Enter command:
      paext32 -o+ -p"install" "install.exe"
      As a result, the “install” directory will not be created and no
      files will be extracted.
      The “install.exe” file may be damaged but if you use a program such as 7-Zip or PeaZip to extract the files, the extraction process is successful. I want the PACL to also unpack such a file.
      This problem is very critical for me. I often come across this. I do not want to resort to using other compression program.
      … Michael
    • PACompXX problem with file name syntax
      BigMike
      there’s a problem with PAComp and file names with a leading ".\ ".
      That’s nowadays a problem, since PowerShell auto complete will complete a file test.zip in the current directory to .\test.zip.
      The first command reports “All OK”, but test.7z is not created.
      The second command reports an error, but the error message isn’t helpful at all. VSS doesn’t help anything if a program fails to write to a file. It’s for reading locked files… And the problematic file isn’t mentioned at all. By the way, there’s a typo, it should be “open”, not “opet”.
      Only the third command (without ".\ ") works as expected.
      The problem exists in the x86 and x64 version, it doesn’t matter if the archive already exists (updating) or not (creating a new archive).
    • czip support
    • PACL 8.0 Beta 1
      spwolf
      Version:
      PACL 8.00 Beta 1
      Whats New:
      Updated to PowerArchiver 2016 engine Fully unicode interface RAR v5 (v4) support PAE2 support Latest format support such as improved ZIPX, ISO, etc, etc, etc.
      http://dl.powerarchiver.com/2016/pacl800b1.exe
      Please test it against your existing scripts and let us know. There will be some features added in future release as well as more testing.
      This is first release, please test. Thank you!
    • pacomp-exe-has-stopped-working)
      P
    • PAConv.bat
      BigMike
      I’ve made changes to fix some problems with PAConv.bat:
      1. Replaced the “” by () in the first two lines, so that it’ll work with command line arguments in quotation marks
      2. Replaced deltree with rmdir, since deltree is unknown at least in Windows XP and later
      3. Also replaced the del command, which left an empty $PATEMP$ directory with rmdir
      4. Changed $PATEMP$ to “%TEMP%$PATEMP$.%time::=%”, so that no write privileges are needed in the current directory as the users Temp directory is used and that more operations will work simultaneous, as long as they are not started at the very same time.
      5. Changed %n to “%~n” to allow parameters with spaces and quotation marks
      if (%1)==() goto help if (%2)==() goto help SET PATMPDIR=%TEMP%\$PATEMP$.%time::=% if exist "%PATMPDIR%" rmdir /s /q "%PATMPDIR%" mkdir "%PATMPDIR%" paext -e -d -p"%PATMPDIR%" "%~1" echo. pacomp -a -r -p -w "%~2" "%PATMPDIR%\*.*" echo. rmdir /s /q "%PATMPDIR%" SET PATMPDIR=
    • Profile Details
      B
    • Pacl 8.0
      spwolf
      PACL 8.0.
      What new features do you guys want from it?
      Current list for 8.0
      RAR 5.x support. Latest ZIP/ZIPX engine with even better performance. Updated rest of engines with latest support for all file formats.
      Possibly:
      New PAF format testing.
      Other things like better logs or what else do we need?
    • How to encrypt file names?
      F
      Is it possible to encrypt file names as well as archive itself using pacl?
      I know you can do this using Power Archiver but not sure about pacl.
    • Problem with large, spanned, encrypted, 7z archive.
      B
      I spent many hours trying to figure out how to use PACOMP to add about 50 Gb to a spanned 7z archive with AES256 encryption, and have yet to be successful.
      I’ve tried every combination of switches I can think of, with no success. Can someone offer a combination of switches that is known to work for this kind of task?
      All I have been able to make is a set of spanned files that PA cannot open.
    • PACOMP -fips and -e2 commands
      F
      Hi
      I am trying to understand what is default encryption method for PACOMP -fips command?
      And what is the difference if you specify encryption method using e[0,1,2] command?
      Using only FIPS:
      pacomp -a -ssecret -fips -p stuff.bh “c:\my stuff*.*”
      FIPS combined with e2
      pacomp -a -ssecret -fips -e2 -p stuff.bh “c:\my stuff*.*”
    • How to add archive comment using pacomp
      F
    • Extracting password protected archive.
      F
      Hi All
      I have archive that holds password protected, encrypted data which is created using something like this:
      C:\Temp\ZipTest>pacomp -a -spassword -fips -e2 archive.zip "C:\Temp\ZipTest" -x"C:\Temp\ZipTest\ReadMe.txt"
      Then I add regular file into that archive which is not encrypted and not password protected. “ReamMe.txt” sort of file. Using command below.
      C:\Temp\ZipTest>pacomp -a archive.zip "C:\Temp\ZipTest\ReadMe.txt"
      Now when I extract this archive using:
      paext -spassword -p"C:\ZipTest\Temp" archive.zip
      Everything extracts correctly except for ReadMe.txt file. File is present but content is empty.
      I get following
      error: extracting: ReadMe.txt --> CRC ERROR! [100%]
      How can I extract archive without corruption ReadMe.txt file?
    Problem with archive
    1
    7109
    • A
      ammiraglio last edited by
      I’m trying to use -ca option in pacomp.exe vers. 4.01 but it doesn’t work! It finish all steps of my job but at least it doesn’t reset archive flag on files.
      I use this options
      pacomp.exe -a -c2 -p -r -ca -x*.tmp
      -$D:\….\file.zip “D:…*.*”
      Any suggest?
      Thanks a lot
