    Extraction Path
    8 Posts 3 Posters 7.8k Views
    • N Offline
      Neroon
      Is it possible to tell PA to initially extract Files not into the Temp-Directory, but into the Directory where the Files should finally reside?
      I´ve tried several Options but it didn´t help. Maybe I´m just blind… :)
      Thanks for any Hints.
        check Options> Config> Misc> Speed options…
        helps?
        • N Offline
          Neroon @spwolf
          I checked the second Option from above under Speed (I am using the German version and its called “Aktuellen Ordner verwenden”; PA 9.62.03), but this didn´t help.
          When i drag a File out of an Archive, PA extracts it into the Temp Directory and then the File is copied via Explorer into the right Location.
            spwolf conexware @Neroon
            ah, it does not work with d&d at this point, if you are using shell, or extract window, it works :-).
            • N Offline
              Neroon @spwolf
              Ah, good to know. Then i can stop trying to get this to work :)
              Thank you for the replies.
              Is it possible/planned to get this to work in a future Version of PA?
                @Neroon:
                yes, we didnt have time to do it for 9.6 since it required a bit of testing, but it will be added in the future for sure…
                • L Offline
                  LanceSteel @spwolf
                  Has this been implimented yet? This drives we crazy when I drag a big file from an archive and it has to copy it after decompressing. I love the software anyway though!
                    it can only be worse now, since Vista requires us to do more work for D&D support :-)
