    Key Problems
    22 Posts 9 Posters 25.0k Views
    • J Offline
      JackRyan
      I’m a german user of PA2005 and I want to use the new version 2006. But there is a problem: It says that my key is wrong in PA 2006?!
      What can I do? Or, what I have to do?
      • J Offline
        JeanPaul
        I think you have to go to http://www.conexware.com/shop/ and log in.
        Click on the “upgrade” icon to retrieve a new code by e-mail.
        • J Offline
          JackRyan @JeanPaul
          Thank you!
            spwolf conexware @JackRyan
            Indeed, all previous PA orders get International keys as well, so you just need to login to get your keys.
            thanks!!!
            • T Offline
              tigers @spwolf
              I just can’t logon since I don’t have a password… Never subscribed there.
                Morty @tigers
                @tigers:
                I have the same problem. The email I received after purchasing my copy just mentions the serial but no password for the conexware site…
                  TBGBe @Morty
                  Two options:-
                  a) If your email address is still valid - use the “Lost Your Password” query :D
                  b) If not, send email to support (at) conexware.com giving your registration details.
                    spwolf conexware @TBGBe
                    Terry is right!
                    Extremly small number of user is not listed on the site, only question is if your email changed or not…
                      Morty @spwolf
                      Terry is right!
                      I was not listed in the database. Nathan just added my account and now everything works fine.
                      Thanks,
                      Martin
                      • A Offline
                        aperry @Morty
                        I’ve sent in a couple of requests to try and get access so that I can get my new registration code, but nothing has been sent back yet. I sent one when we got the notice that a new version would be out soon, and then again this past weekend.
                        How long does it generally take to get a response with login/pw information?
                          spwolf conexware @aperry
                          @aperry:
                          If your email is not registered, you will need to contact support via contact page above and explain your situation.
                          If your email is in the database, response is automatic.
                          • A Offline
                            aperry @spwolf
                            I did that, twice. My email address has changed since my original order, but I did include a copy of the original confirmation email showing my previous email address along with my current email address.
                            Guess I just have to wait a little longer…
                            • T Offline
                              tigers @aperry
                              Same for me. I’m still waiting for an answer. In the meanwhile I have to wait for the countdown every time. Annoying…
                                TBGBe @tigers
                                Just to be 100% certain.
                                If the email address you used when registering PowerArchiver is no longer valid, then you cannot contact Conexware via the Account / Shop page because the auto-response will still go to the “old” address!
                                You should complete the online support request form { or send an email (from your correct address) to support (at) conexware.com} giving your original registration details and clarifying that your email address has changed.
                                T N 2 Replies Last reply Reply Quote 0
                                • T Offline
                                  tigers @TBGBe
                                  Yes, I understand, but that address is still valid, but empty.
                                  I’ve been recontacted now, but it seems a long procedure…
                                  • N Offline
                                    Neroon @TBGBe
                                    @TBGBe:
                                    I did that 2 Days ago (sent Mail to Support Address). No answer yet.
                                    Will keep waiting. :)
                                      spwolf conexware @Neroon
                                      @Neroon:
                                      send it again, we either didnt receive it or you didnt receive our reply.
                                      • N Offline
                                        Neroon @spwolf
                                        Done :)<br /><br />Subject is “PA 2006 Key / Log-In into Account” and it comes from “Neroon <neroon (at)
                                        darkness.ruhr.de>”
                                        • N Offline
                                          Neroon @Neroon
                                          Some Mailing with Drazen solved the Problem. :)
                                          • R Offline
                                            rickdeckard @Neroon
                                            I have exactly the same problem.
                                            I have a very old lifetime key that I can’t use with the new version. I even still have the original mail where Drazen sent the original key.
                                            However i couldn’t login because my email-address since then has changed.
                                            The first time I mailed to the customer support I got a mail like ‘no problem, send us your private data and we will create a new account for you’.
                                            I did that - however I never got an answer nor am I able to request my login data by that email (that I put in my answer mail) over the website.
                                            Now comes the interesting part:
                                            After that I mailed about 6 times to the customer support. I don’t get an answer at all. After the 2nd time I deactivated all my spam filters since I was suspecting that any answer mail got stuck. Nothing.
                                            I was about to convince my company with 300 people with use Powerarchiver instead of Winzip. Since it offers alot more feature with the same interface - but with this current support behaviour I am stuck at the moment.
                                            So please… Dear support people… if you read this - please help! You can contact me using this board for example. I checked that mail coming from this board is going through (I could not have registered otherwise)
                                            From Germany, Hamburg
                                            Carsten Schmitz
