    Problem with FTP inside Backup Express Script
    • K
      KongTan
      I am using PA V9.00.32 on a XP-Pro machine.
      I have created a Backup Express script to backup a folder and upload the zipped file to the FTP Server.
      When I run the script, it created the zipped file, but did not even attempt the FTP upload.
      When I view the script file (.PBS) with notepad, the FtpArchive=1 and FtpProfile=FTPServer
      If I opened the zipped file in PA, then select File/FTP Archive… menu option, it uploaded the file to the FTP server without any problem. (Using the same FTPServer profile).
      Please let me know if you need more info.
      Thanks for all the help.
        This is an known issue - as a workaround, enter your ftp ip/address to the Name field and it will work. Will be fixed in next update.
        thank you,
        • ivanI
          ivan conexware @spwolf
          Confirmed!
          The issue will be fixed in next release!
