    Strange fonts in Compress To window
    6 Posts 4 Posters 8.0k Views
    • R Offline
      Ricco
      I’m using Traditional Chinese WindowsXP Home SP2 with all default settings in fonts. I found that the fonts in Compress To window called out by Shell menu are quite “ugly” and is not the same with fonts used in main window.
      I’ve attached two files… pa.gif would be the “Compress To window” and pa_2.gif would be the generic PA main window form. Note that the fonts are quite different.
        ivan conexware
        It seems they are the same, but the size is different?
        • R Offline
          Ricco @ivan
          I have no idea… but it looks just different from those in the main window and uneasy to read. Is there any method to change it?
            spwolf conexware @Ricco
            @Ricco:
            so text is actually the same, it is font that is different?
            • R Offline
              Ricco @spwolf
              Yup… the font is different.
              So maybe it used wrong fonts?
                TBGBe @Ricco
                Both screen shots seem to be using the same font
                Look at the word Encrypt on the Toolbar button and Option list.
                PA menu uses Windows settings.
                I cannot identify the font you are using - maybe Times New Roman
                but the ‘y’ in Encrypt is “unusual”
                Right click on your desktop and select
                Appearance, click on Advanced button
                Then under Item select the dropdown option Menu
                What do you have for Font ?
                You can change it here if you wish.
                On my PC it is Tahoma.
