    General program question
    3 Posts 2 Posters 5.3k Views
      davidsplash
      which program did you create the (chm) help file in. Just out of curiosity
        Serhiy
        You may use the Microsoft HTML Help Workshop:
        http://msdn.microsoft.com/library/default.asp?url=/library/en-us/htmlhelp/html/hwMicrosoftHTMLHelpDownloads.asp
          davidsplash @Serhiy
          Thanks for that. I know about that just thought we should know what made it, so we understand if there are any errors in the help and why they might be there. Also i want to know if they used something different as i was hoping to use chm files for my own programs.
