    A ASkripts
    Wishlist
    W Werve
    Wishlist
    2 Votes
    Z ZebraPower
    Wishlist
    PA_FanP PA_Fan
    Wishlist
    C charlesbotz
    Wishlist
    paq9a support
    R richwood
    Wishlist
    Wishlist
    Wishlist
    BigMikeB BigMike
    Wishlist
    OneDrive for Business support
    Z ZebraPower
    Wishlist
    BigMikeB BigMike
    Wishlist
    2 Votes
    A a.borque
    Wishlist
    BigMikeB BigMike
    Wishlist
    F falco99
    Wishlist
    D DaTreeDude
    Wishlist
    2 2Flo
    Wishlist
    Wishlist
    Folder navigation
    drteethD drteeth
    Wishlist
    Quake 1/2 .PAK file support
    AluminumHasteA AluminumHaste
    Wishlist
    Find file in archive.
    Wishlist
    [Bug] Ctrl+A does not work in explorer view
    15 Posts 7 Posters 18.1k Views
    • ? This user is from outside of this forum
      Guest
      Ctrl+A does not work in explorer list view.
      • manuangiM Offline
        manuangi
        I can confirm that.
          Guest
          When in explorer view it is not possible to select multiple files. Neither the left/right mouse button or any key combination works.
          Maybe you forgot to set some properties? :D
          SpAwN oF T.D.F.S 1 Reply Last reply Reply Quote 0
            Guest
            It is not possible to drag and drop files from PA when in explorer mode. Neither the tree view or the list view allows drag and drop.
              Guest
              The menu commands Large Icons, Small Icons, List and Details don’t work in explorer view. If I select one of these options the status of the menu command changes but nothing happens with the icons in the explorer view.
              ? 1 Reply Last reply Reply Quote 0
                Guest @Guest
                The submenu “Arrange Items by” is grayed out in explorer view so that it is impossible to sort the items with keyboard or menu. Also the “Refresh” command is grayed out.
                  spwolf conexware @Guest
                  @postman:
                  thats because they can be only used when archive is open. We will tie them in with Explorer view (w/o archive open) for 9.1.
                  • SpAwN oF T.D.F.S Offline
                    SpAwN oF T.D.F. @Guest
                    At me it works… :D
                      spwolf conexware @SpAwN oF T.D.F.
                      I have grouped all of the “explorer view” threads into one, for future version wishlist. We had to change our explorer view very close to release date since our old one started having issues in Delphi 7.
                      There are plenty of missing features in Explorer view, even in addition to ones posted here, and hopefully we will take care of all of them for 9.1.
                        spwolf conexware @spwolf
                        p.s. to clarify, this is for explorer view, without archive open.
                        • R Offline
                          rev23dev @spwolf
                          does that mean drag and drop folders in explorer view will be taken care of for 9.1?
                          :cool:
                          spwolfS D 2 Replies Last reply Reply Quote 0
                            spwolf conexware @rev23dev
                            @rev23dev:
                            :cool:
                            You mean as in archive paths? Nope, this is only for explorer view, without archive open. But having support for drag & drop of path folders would be nice definetly, and please keep mentioning it :)
                              daft @rev23dev
                              @rev23dev:
                              :cool:
                              I really hope so. This is the ONLY reason why I prefer WinRAR over PA. I’m amazed that so few archivers support something as simple as this. I’d be very pleased if the new PA can do this.
                                ivan conexware @daft
                                Explorer view improvemetns will be made for 9.1.
                                • G Offline
                                  Guestus @ivan
                                  Huge feature missing: pressing a letter on the keyboard doesn’t take you to the folder that begins with that letter. That’s very uncomfortable and annoying. Please…fix it.
