Navigation
    • Update script error
      when clciking on powerarchiver update from within powerarchiver we get a windows for the update but it nows sayes script errors. I think it could be due to windows update in windows 10 can you look into it. By pressing cancel it seems to be ok. It seems that the page being displayed as erros on it.
    • PA 2.00.01 macOS extract popup not showing buttons
      F
      From within PA on the extract popup, buttons are hidden, I must resize the window to get access to the OK/Cancel buttons. Tried on the default notebook screen (Macbook M1 Max 14") as well as on my external monitor (4k).Screenshot_2022-05-12_10-02-10.jpg
    • PA 2.00.01 macOS directory separator inside RAR
      F
      Just uncompressed a RAR file that has a folder within, PA created the folder but the files inside are not being saved into folder because directory separator is a BACKSLASH (Windows style) instead of SLASH (macOS).Screenshot_2022-05-12_09-59-08.jpg
    • Conexware update
      OS: W10 21H2 19044.1645
      Best regards
      Wilfrid
      PS: Keep building such good software
    • PDF Encrypt and Sign Section Missing
      Ho già contattato il supporto con il modulo presente qui https://www.powerarchiver.com/it/contact/ da settimane ma non ho ricevuto riscontro e ora che ho aggiornato alla versione 21.00.15 ho notato che il problema persiste.
      Quando clicco PDF Encrypt & Sign nel tab Crittografia appare la schemata riportata sotto come se mancassero le funzionalità.
      I’ve already contacted support with the form here https://www.powerarchiver.com/it/contact/ weeks ago but I haven’t received any feedback and now that I’ve updated to version 21.00.15 I’ve noticed that the problem persists.
      When I click on PDF Encrypt & Sign in the Encryption tab the schematic below appears as if the functionality is missing.
    • PowerArchiver 2022 Final does not find external DVD-Burner
      U
      I have tried to burn a DVD with PowerArchiver 2022 Final, but it didn’t work because PA didn’t found the external DVD-Burner.
      I have tried several burners from Sony, LG, Dell.
      I have connected the burners with several USB-Ports but unfortunately without any success.
      With other burning software, e. g. Nero, all burner worked perfect on each USB-Port.
      The same problem occured with PA2018 and it was solved with an update, but I don’t remember the detailed software version.
      Could you check the possibility of an bug, please?
      Thank you for your support in advance!
    • PowerArchivier don't save Created and Accessed timestamp
      Quando creo un archivio zip con un altro programma ad esempio Winrar se apro il file con Winrar vi sono visualizzati anche le date originali di Accesso e Creazione.
      Se ottimizzo quel file zip con la funzione Ottimizza archivio di PowerArchivier (o creo un nuovo archivio) il file risultate non ha più le date originali di Accesso e Creazione.
      C’è una opzione per preservare questi dati? (Non l’ho trovata nelle impostazioni del programma e ho già abilitato le opzioni “salva info complete cartella” presente in “Profili di compressione”)
      When I create a ZIP archive with another program such as Winrar, if I open the file with Winrar, the original Access and Creation dates are also displayed.
      If I optimize that zipper file with the Optimize Archive function of PowerArchivier (or create a new archive) the resulting file no longer has the original Access and Creation dates.
      Is there an option to preserve this data? (I haven’t found it in the program settings and I have already enabled the “save complete folder info” options in “Compression Profiles”)
    • Unlisted pbs files
      pirrbe
      Upgraded from 2021 to 2022. Selecting ‘backup’ no scripts are showed. Only after editing and saving an existing script (explorer) it shows up in the PA backup folder.
      So is the ‘backup’ icon to open the Backup screen only for creating ‘new’ ones. This means that you have to open ALL your old pbs files and to save them again… not user friendly.
      No way to improve this ? Thank you.
    • Fast/Slow Ring: PowerArchiver 2022 Final - 21.00.15
      M
      PowerArchiver 2022 - Final Version - 21.00.15
      https://powerarchiverdl.cachefly.net/2022/powarc210015.exe
      Information about PowerArchiver 2022 - 21.00.15:
      https://www.powerarchiver.com/2022/04/05/welcome-to-owerarchiver-2022/
    • Access violation with scaling > 100%
      K
      I have a 31" 4K screen with 3840x2160 pixel, which PA is able to handle - except of a scaling other than 100%.
      When changing scaling for this screen to 125%, starting PA brings the following exception:
      Access violation at address 0000000..DF47A4 in module 'powerarc.exe'. Schreiben of address 0000...00330.
      After closing this message, PA seems to work fine.
      PA version 21.00.15 (03/2022) 64bit (tested with Win 10 and after upgrade Win 11)
      Is there any chance to avoid this access violation or this message?
      Thanks and regards,
      Karsten
    • PA 21.00.13 *.tar.xz open okay but *.txz doesn't
      Brian Gregory
      Example file: http://www.kk5jy.net/smalldv-v1/Software/smalldv-1.0-beta-20180619a.txz
      PA 21.00.13 doesn’t seem to see the contents unless I change the extension to .tar.xz
    • configure clouds hangs up system
      pirrbe
      This are the steps :
      in Options, select ‘configure clouds’ try now to quit this option…
      No way, everything is locked up, the only way is using the task manager to quit PA.
      (version 2021-20.10.02)
    • 2022 RC 2: Adding file to existing archive breadcrumb nav does not work
      MarcFou
      When adding a file into an existing archive, in the add file window, if you click in the breadcrumb bar to navigate to a parent directory, the file list does not change. The directory Up button works.
      Running x64 on Win 11
    • About box slightly messy on PA 21.00.13
      Brian Gregory
      blue text over graphic: (graphic too low?)
      (Running on 64 bit Windows 7)
    • Windows 11 context menu "Open with PowerArchiver" doesn't work
      BigMike
      In PA 21.0.13, when I try to open an archive with the new Windows 11 context menu item “Open with PowerArchiver”, a PowerArchive instance is opened, but the archive is not loaded.
    • PA 2022 Windows 11 context menu not translated
      BigMike
      the new Windows 11 context menu is not localized in PA 21.00.13.
      While the classic context menu is localized, when it’s opened on a file on my desktop, it’s English, when it’s opened from a file on my C drive.
      @Mili Are there updated localization files available?
    • Problems with registry restrictions on PA 2021 and sending reg codes
      BigMike
      I thought, I’ll give it a try and upgrade my PA 2018 Toolbox on my production machine to PA 2021 (20.10.03)
      Sending registration codes in your order recovery doesn’t seem to work at the moment (I also checked my junk folder), online activation works Using registry to disable modules (for example HKLM\SOFTWARE\PowerArchiverInt\General\DisableBurning) doesn’t work as expected with modern ui. The module is visible, but I’ll get the trial nag, if I try to open it. It’s almost fine in classic and ribbon mode.
      “DisableClouds” and “DisableExplorer” seem not to be respected at all, while the classic UI seems to respect the setting to disable any other unused module:
      In settings I won’t be able to access the SmartAI settings and the settings for the internal editor if the FTP module is disabled
    • Is PA 2022 clear with old bugs?
      G
      PA Queue does not compress file optimally with same parameters if used in Queue mode.
      Being able to save advanced option, and set a default profile and archive type for compression so I can save clicks.
      The above two are majorly affecting my efficiency with archiving stuff with PA 20.10.03.
      Can someone confirm if they are resolved with the 2022 RC1?
    So much excited waiting for 9.5
    • R
      Ricco last edited by
      I still need the help from xxxRAR to extract ISO file now. Really excited waiting for the ISO support from PA.
      Would it be available in July? :D
      • spwolf
        @Ricco:
        I was going to say - sooner! But time flies by… expect beta in 10 days or so…
        • R
          Ricco @spwolf last edited by
          10 days! It’s good to hear that!
          • A
            Annorax @Ricco last edited by
            ISO support will be great, making this a pretty much comprensive tool for all compression needs. Here’s some related questions:
            Will PA also support BIN and CUE files along with ISO?
            I don’t think this is possible or needed for a compression program, but mounting ISO images (similar to Daemon Tools) would be sweet as well.
            • K
              klumy @Annorax last edited by
              there should be read support for BIN, ISO and NRG
