    ZIP SFX: AES Problem
    8 Posts 4 Posters 8.8k Views
      Serhiy
      PA’s SFX module can’t extract AES encrypted ZIP archives…
      Here is an example:
      http://www.gorosoft.c-f-h.com/files/pa-test/sfx-aes.exe
      (pass: q ) - but it will not prompt for it…
        Using PA 9.21 (explorer shell) I was prompted for password and extracted “kassa_plat.xls”.
        Double clicking the exe file gave me a PA menu which is in a different language
        Choosing last option (of the 5 buttons, maybe open with PA ??) then extract again asked for password.
        • A Offline
          amh209 @TBGBe
          I had the same experience as TBGBe
            Serhiy @amh209
            I am sorry, this is Ukrainian language…
            You are right, PowerArchiver can extract it…
            But this is SFX archive!!!
            Try pressing the first button (Extract)
            it will show the error message (“Can’t extract selected file(s)”)
            instead of asking the password…
              TBGBe @Serhiy
              OK.
              I can reproduce the problem as follows using PA 9.21 :
              Using PA create a Zip file with AES 256 encryption.
              Then use PA “make exe” option (I did not select the test option).
              Run the resulting exe and pressing the “Extract” button gives the error message
              << The selected file(s) couldn’t get extracted >>
              However, pressing “Open with PowerArchiver” works and prompts for the password.
              Note: For this message a better text would be
              The selected file(s) couldn’t be extracted.
                Serhiy @TBGBe
                You are right.
                  spwolf conexware @Serhiy
                  PA’s SFX module can not read AES encrypted ZIP archives yet, so it will not work properly. I am moving this to the wishlist for the future reminder.
                    Serhiy @spwolf
                    PA’s SFX module can not read AES encrypted ZIP archives yet, so it will not work properly. …
                    OK, but it would be better if PA’s “Make .EXE” feature can check whether zip-archive is AES encrypted and then
                    abort creating an incorrect exe-file…
                    (this is my wish)
