    Display forum dates as DD-MM-YYYY instead of MM-DD-YYYY
    6 Posts 3 Posters 8.8k Views
      deipotent
      I thought there would be an option in the User Control Panel but there isn’t. Any ideas ?
      • K Offline
        klumy
        I think the admins have to aneble this function in his admin center
        • K Offline
          klumy @klumy
          could this please also be changed ;)
            spwolf conexware @klumy
            We are an US company, so the dates will have to stay US spec. :-)
              deipotent @spwolf
              Fair enough. It doesn’t look like this can be configured on a per user basis with vBulletin.
              How about enabling the display of attached uploaded images in posts though since this can be configured on a per user basis, as long as it has been enabled at the Admin level. I guarantee that any users who don’t want to display the images (eg. due to being on a slow connection) can simply disable this by going into their Forum User Control Panel.
              EDIT: I was wrong about the date format - Just got this reply about the date format from someone at vBulletin
              “This is a feature that can only be set globally by an Admin. However you can set it per language so if a language has a particular date format it can be used. The end-user’s date representation will change when they change languages.”
              Can you also enable this feature please…
              • K Offline
                klumy @deipotent
                there is a per user setting in vbb which allow this !!
