    Problems with Color-scheme after upgrade to build 73
    2 Posts 2 Posters 1.3k Views 1 Watching
    • A Offline
      a.borque
      I am using the portable version of PA2021. After switching from build 58 to 73 I have problems with the color-scheme:
      While 58 behaves like expected and showed everything in light or dark colors according to the settings, 73 always shows the lower part of the window in dark colors, no matter whether I select automatic, light or dark.
      This happens on a clean installation of 73 as well as on an update from build 58. I have attached two images generated on the same machine at the same time with the same settings. The upper shows build 73, the lower 58. Is it a bug or some changed setting I miss?
      Thanks for help!
      A.Borque
        Mili conexware @a.borque
        Thanks @a-borque
        There were updates to the skinning and interface components in latest version. We have confirmed the issue in the portable version and have logged it in for fixing in the next version.
        Thanks for letting us know!
