    Right-Click Compression
    2 Posts 2 Posters 1.0k Views 1 Watching
    • Z Offline
      zornestech
      In windows 10 you can right-click and select send to and the compressed zipped folder and the zip folder will contain the name of the last selected file.
      Does PowerArchiver have a similar function?
      Tom
        hello @zornestech
        Yes, PowerArchiver does have right click compression which is also configurable from PowerArchiver’s Configuration options.
        The right click options are available for easy compression and extraction, tools access and more.
        Let us know if you have any further questions.
