    PA Not responding issue and Pause issue
    3 Posts 3 Posters 1.3k Views 3 Watching
    • G Offline
      godlydevils
      So my rig is as below:
      CPU: Intel® Core™ i7-4720HQ CPU @ 2.60GHz (Turbo 3.7GHz)
      RAM: 16 Gigs DDR3
      Samsung SSD 860 EVO
      Windows 10 pro for workstations x64, freshly installed on 22nd Dec 2020, and updated.
      PA freshly downloaded on same day, so it’s 2021 x.x.62 version
      Issue and reproduction:
      If you start a compression, and if it’s mid way anywhere or even started, and you try to cancel it, the window will get stuck there, another click or key press will make the window not responding, then, and more will make windows to collect logs for crash, and the process will be terminated by windows
      On the other hand.
      If the process is mid way, and if you try to pause it, the compression, CPU utilization, RAM usage will stay/increase as if the compression if still going on, the whole process will take it’s course, instead of doing what we clicked on.
      So, both pause and cancel buttons are useless.
        hey @godlydevils
        we’ve had this issue before, fixed it and it seems to have returned.
        logged back in for fixing, thanks much for letting us know!
        • Brian GregoryB Offline
          Brian Gregory Alpha Testers @Mili
          @mili It was never really fixed very satisfactorily.
