    PA does Negative compression, but 7zip does positive compression for same set of files
    1 Posts 1 Posters 832 Views 1 Watching
    • G Offline
      godlydevils
      You can obtain the original file from here:
      https://pcsupport.lenovo.com/in/en/products/laptops-and-netbooks/lenovo-y-series-laptops/y50-70-notebook-lenovo/80ej/59428436/cb32343883/downloads/driver-list/component?name=Power Management
      For Lenovo Y50-70 win 7 x64 bit, power management, get lenovo energy management
      Run the exe it will extract the installable drivers to C:\drivers
      I tried to compress the whole folder using PA using following parameters:
      Extreme, strong optimize.
      This resulted in negative compression.
      However same file is compressed by 7zip alpha, with positive compression:
      I understand that there are different algorithms, parameters used, and totally different software with unique sets of logics programmed, but see if compression algo can be optimized for such files.
