    Virtual drive issue
    2 Posts 2 Posters 978 Views 2 Watching
    • drteethD Offline
      drteeth
      I have v20.00.58. If I right click on an ISO and click on ‘mount as virtual drive’, nothing happens. If I go directly to create Virtual drive by following burner > virtual drive, I can select an ISO. I then was foxed by the ‘start’ button. I do not thing that ‘start’ is an appropriate word to use when something happens instantly. There is no indication that anything had happened. I had created 4 identical virtual drives before I figured out what was going on. ‘Start’ means beginning a process. ‘Create’ would infer that the process is immediate, which, it is. Similarly, ‘unmount’ is more appropriate when unmounting rather than ‘start’.
      Mounting and unmounting virtual drives can only be done through PA and not right click menus. The attached is what appears when I try to unmount with a right-click.
        Hi @drteeth
        as a temporary fix, please delete PAVD2021.EXE from the installation folder and install virtual drive again, then it should work fine until we fix it so the error doesn’t appear at all.
