    File will not extract, takes forever to finish.
    12 Posts 4 Posters 4.1k Views 3 Watching
    • Brian GregoryB Offline
      Brian Gregory Alpha Testers
      This file will not extract: http://www.dsp4swls.de/download/sodiraSDR_wavefiles.zip
      I think it’s slightly corrupt so PowerArchiver should show an error message but instead it just sits there forever doing nothing.
      Later edit: I should add I am using PA 19.00.59.
        thanks, @Mili will check it out.
        • guidoG Offline
          guido
          7zip says the file is corrupt. But somehow PA cant handle the error.
          Windows 11 Pro ENU x64
          Intel Core I7
          32 GB RAM
          Brian GregoryB 1 Reply Last reply Reply Quote 1
            Brian Gregory Alpha Testers @guido
            @guido said in File will not extract, takes forever to finish.:
            Good. That’s what I thought.
              confirmed here as well and logged in for fixing, thanks @Brian-Gregory !
                Brian Gregory Alpha Testers @Mili
                @Mili Keep a local copy of the file. They said they will fix it on their website soon!
                  Mili conexware @Brian Gregory
                  @Brian-Gregory said in File will not extract, takes forever to finish.:
                  Thanks! will do
                    @Brian-Gregory is this ok in .28? thanks!
                      No, It still seems to just freeze using no CPU and doing nothing when it comes to the error.
                      Later: What’s supposed to happen? Could it be a Windows 7 only problem?
                        spwolf conexware @Brian Gregory
                        @Brian-Gregory no, i think it got lost while we were closing issues with PA 2021. I bumped it up. Thanks!
                          Seems to be fixed in PA 2021 20.00.32.
                            Thanks for your help @Brian-Gregory !!
